Old 02-23-2015, 10:54 AM
AX-O's Avatar
AX-O AX-O is offline
Default 90 swivel fitting question.
All,
I am looking for this fitting in steel for my oil cooler. I can only find it in aluminum. Does anyone have a clue where I can find it? Thanks for any help.
http://www.highflowfuel.com/i-674727...npt-black.html
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 02-23-2015, 11:05 AM
Gisnar Gisnar is offline
Do you need the swivel? I would most likely use a steel an to NPT 90.
Old 02-23-2015, 11:22 AM
AX-O's Avatar
I don't need it. But that's what I want to use in order to make the clocking of the fitting more accurate and not have to worry about over torque.
Axel
Old 02-23-2015, 11:46 AM
bret's Avatar
bret bret is offline
I would worry about the internal O ring wearing out with vibration and causing an oil leak?
Old 02-23-2015, 11:56 AM
krw5927 krw5927 is offline
http://www.amazon.com/Aeroquip-2249-.../dp/B008I50LSA
I didn't even know these existed. Would sure save some trouble clocking oil cooler fittings!
Kurt W.
RV9A
FLYING!!!
Old 02-23-2015, 11:15 PM
Same issue as above. Swivel nut crimped over stem with an O'ring. Common in industrial use. "Can" leak slightly at low pressures.
Better solution, if you wanted an 'adjustable' fitting would be be to
A) find a cooler with O'ring boss ports, and use straight thread o'ring boss fittings
B) use a NPT male to O'ring boss adapter at the cooler, then use a o'ring boss fitting.
Too many fittings, and too expensive a cooler for most of us.
Tom
Ridgeland, SC
