  #21
Old 02-24-2015, 02:29 PM
E. D. Eliot E. D. Eliot is offline
Default I'm interested
Scott - I'm interested in the product that you talked about . Also, do you know if this product is available in one gallon/quart cans so that I can use it with my HVLP sprayer? Thanks.
Building finally
Old 02-26-2015, 09:14 AM
longline longline is offline
Default sem ez coat
Is the name of the product that was recommended to my by the tech people at SEM. I am using a darker grey color, but there are all sorts of others. It does not appear to be very temperature sensitive; I have applied it at 45 degrees with good success. It flashes off very quickly, very quickly. Hit it with a heat gun for a while to "set" it and continue to rivet. Their website has several interesting videos on the product. It is not as durable as an epoxy product, but it is plenty durable for our use and is easily repaired if damaged.
I kind of choked on the $15 price per can, but after using it I think it is a bargain. (Remember that there is no priming required for Aluminum.)
