Notice that you are mixing things a bit. Flaps and trim.
Basic kit has just a switch (hold down, flaps go down) for flaps. Or you can add a controller with pre- set positions.
For pitch trim, basic kit has a one speed motor, no runaway protection other than pilot pulling circuit breaker. You can add speed control, runaway protection with the add-ons. Some autopilots (Trio, I know) will give you trim speed control, or you can buy a module. I strongly recommend trim speed adjustment of some kind. The stock is about right for low speeds but too fast at cruise.
