Originally Posted by RV7Guy
I am a huge proponent of safety and minimizing risk by taking reasonable steps to eliminate "points of failure."
There seems to be a general hysteria on many lists and forums about the concern over various component failures especially in the area of switches. However on the same forums you rarely, if ever, hear of these actually occuring. Redundancy this and that, also adds to the complexity and to the opportunity for something else to fail.
If I were to be concerned about switch failures I be just as concerned about the Master switch failing along with the Radio Master since they are acuated virtually the same number of times. Neither seem to be an issue.
Great discussion.
Darwin, I agree about your comment on complexity, and adding more stuff to allow for failures. My personal observation is the IFR pilot/builders are the most guilty of this, adding extra equipment to allow for other equipment to fail....
However, following AeroElectric Bob's bus architecture adds little complexity. Using his generic light aircraft example here...
http://www.aeroelectric.com/PPS/Adob..._Pdfs/Z11K.pdf
The only extra "stuff" added is a diode and an alternate feed switch, and splitting a single power bus into 3 smaller busses. Very little extra complexity, with a definite payoff.
You will notice that the Alternate Bus feed comes directly off the battery, so if there is a Master Switch failure, or a Battery Contactor failure (more likely), you will have enough electronics able to be powered to make a safe landing at a nearby airport, as opposed to a complete electrical failure, and loss of all electronics.
As a member of the Grumman Gang mailing list, I see regular postings on switch and contactor failures, and some pilots even carry extra switches in their travel tool kit. They are cheap switches though....
The AeroElectric sample diagrams are worth their weight in gold, and if implemented really do not add to the system complexity, but give good redundancy to make a safe landing, even if not at the intended destination. Sounds like a good safety system to me.
I don't know what redundancy and/or safety measures are built into the EXP Buss.... do you know of any?
gil in Tucson - I think we have less electrical problems here in AZ due to a lack of corrosion effects....
This doesn't remove mechanical type problems, such as vibration though...
