11-02-2006, 07:35 AM
Single Point Failure..
Originally Posted by jcoloccia
So Nuckolls calls this second bus the "essential bus" and swears up and down that a switch is not nescessary. He's probaby right, but that's not the point. By using redundant paths the whole switch/no-switch argument becomes irrelavant. The likelyhood of TWO switches failing at the same time is really teeny weeny....even if you use the cheapest "Made in the Peoples Republic of WeMakeCheapUnreliableSwitchesIzstan" switches. Now sure, you're not going to get anymore reliable than getting rid of the switch entirely but if you have redundant feeds, a switch on each one doesn't significantly reduce your SYSTEM reliablity anymore and it sure is convenient to have.
And that is exactly the definition of a "Single Point Failure" that has been removed.... as mentioned in post #3.....
Most small aircraft do not use the "Essential Bus" concept, and feed all of their avionics through a single Master switch wired to the single power bus... the "single point failure".
I think AeroElectric Bob changed the terminology to "Endurance Bus".. but it seems to be the same thing.
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
11-02-2006, 07:40 AM
Radio Master Switch Failure
I personally know people who have lost switches in flight, myself included.
(1) So help me understand this switch failure, did the switch that failed fail during activation or was the appliance in operation and just "lost power", (we are talking about a properly sized switch that is not running hot).
(2) second question, other than the extra switch etc, what is the difference between Bob's so called "essential bus" and just wiring the avionics bus straight to the battery and turning all avionics equipment off/on with their panel switches?
George McNutt / Langley BC / 6A Sold / 7A Flying.
11-02-2006, 07:45 AM
Old age?
Brain farts..... leave one item of the Avionics stack ON, and no juice to start the plane when you come back the next week...
Only one switch to remember to switch off....
gil in Tucson
Gil Alexander
11-02-2006, 10:17 AM
Originally Posted by az_gila
Interestingly enough, Garmin recommends that it not be powered during start-up....
Where does Garmin recommend that the GTX-327 not be powered during start up? I'm a bit baffled why they would make that recommendation, as the Installation Manual clearly states that the GTX-327 meets the DO-160 Category A qualification for voltage spikes.
11-02-2006, 10:27 AM
An individual from the Matronics AeroElectric List forum has replied to me:
"Pin 1 is avionics power on; Pin 15 is 'power input (11-33V)'. I believe if you wish it to remain off you need to disconnect pin one and run power to pin 15."
This seems to confirm what William posted here previously. Now all of you get busy and go read the Nuckolls bible, 'Aeroelectric Connection' and follow the path to enlightenment :-)
Thanks for the help guys.
Erich
11-02-2006, 10:36 AM
1) I've had a couple fail in flight while they were on. Landing light once. T&B gyro, of all things, another time. Go figure...maybe I'm just unlucky.
2) Nothing. The only real debates are whether or not to put a switch on it and whether to also power the avionics from the master bus. If you do Master bus AND dedicated avionics bus (direct from the battery), and put a switch on both, you have a very reliable system.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
11-02-2006, 10:46 AM
In the Manual....
Kevin,
In the Pilot's Manual that is on-line at the Garmin site... in the free area...
http://www.garmin.com/manuals/GTX327...ilotsGuide.pdf
gil in Tucson - and yes, I was surprised at that....
Gil Alexander
11-02-2006, 11:02 AM
Well that's provides a little discomfort to me (meaning Garmin says the 327 should be off for starting). I have my 327 on the essential buss along with my EIS 4000. I have it on during start-up so I can see oil press and rpm...
so far the 327 hasn't complained and people seem to see me on radar just fine.
- Scott
11-02-2006, 11:15 AM
VAF Moderator / Line Boy
Don't worry Scott - ours will die togetehr...mine is on for engine start as well, and I don't let it bother me....
Now lightning strikes are another thing....THOSE I'll worry about....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-02-2006, 01:01 PM
Failure this and failure that!!
I am a huge proponent of safety and minimizing risk by taking reasonable steps to eliminate "points of failure."
There seems to be a general hysteria on many lists and forums about the concern over various component failures especially in the area of switches. However on the same forums you rarely, if ever, hear of these actually occuring. Redundancy this and that, also adds to the complexity and to the opportunity for something else to fail.
My aircraft is equipped with the EXP Buss switch panel. It has a dedicated "Radio Master" switch. I have all avionics including the Dynon 10A on this master. It is completely isolated from the start process and therefore protected from spikes etc... All of the power is going to the start process. When the engine is stabilized at 1000 RPM and I have proper oil pressure and fuel pressure, I hit the Av Master.
If I were to be concerned about switch failures I be just as concerned about the Master switch failing along with the Radio Master since they are acuated virtually the same number of times. Neither seem to be an issue.
If doing all again, I would not use the EXP Buss system in favor of conventional switches but I'd definitely use an Avionics Master.
Now watch, now that I've talked about switch failures, I'll have one tomorrow when I fly to Big Bear to have lunch with CA boys tomorrow.
Great discussion.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
