I went and talked to our Mechanical designers at work and they pointed me to this table... small portion copied here....
Screw Size .138-32 (#6)
Lubricated Screw Threads 12 in-lb.
Dry Non-Locking Threads 14 in-lb.
Dry Locking Threads 16 in-lb.
Screw Tensile Stress Area (sq. in) 0.00909
This is for 80,000 psi material... scale it down for the AN507 55,000 psi screws, or use better screws...
Also note that these numbers include an allowanace for the friction drag, don't add extra....
I guess they don't want the assembly people doing mathematical calculations.
These numbers are good for unmanned, guided, high speed aerospace vehicles.... should be good enough for our RVs....
Test first....
Data is derived from M. F. Spotts, Design of Machine Elements and Mechanical Engineering Design by Joseph Shigley.
gil in Tucson
