Old 02-11-2015, 02:20 PM
ldknepp ldknepp is offline
Default Rudder Leading and Trailing edge advice needed
I have reached the Rudder leading and trailing edge step and am very concerned that the hours and hours of research will not fully prepare me for the horror of trying to do this right the first time. Can someone explain how to do this successfully without gluing the angle to the rudder and having to chisel out the clecos once the glue is dry.. and then there is the front edge. How do you ben it and make it look nice? HELP!!
Old 02-11-2015, 03:01 PM
YellowJacket RV9 YellowJacket RV9 is offline
Spray the clecoes with teflon or similar. Even without it though, they will be easy to remove. Don't use gobs of sealant and there won't be too much sticking to the angle. It comes off without much of an issue. It's really not that bad!
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 02-11-2015, 03:38 PM
Chris
Thanks Chris
Old 02-11-2015, 04:04 PM
BillL BillL is offline
Default DejaVu
http://www.vansairforce.com/communit...d.php?t=122655
Bill
RV-7
Lord Kelvin:
