Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 02-09-2015, 02:53 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Humidity vs. how often to retorque Wood/Catto props
I've always known that wood or wood-core props, like my Catto, need to be retorqued periodically to compensate for seasonal humidity changes. For parts of the country that are pretty humid year round, when (or if) this happens probably doesn't matter very much. However, for those of us in the dry part of the west, where the humidity fluctuations throughout the year are pretty significant, how often should this be done? Just twice yearly (once during the 'dry' season and once during the 'wet' season) or more often that that?
Based on the following monthly average humidity chart for where my plane is based, when would you recommend I do my periodic retorques?
FYI, the chart came from:
https://weatherspark.com/averages/30...-United-States
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-09-2015, 04:25 PM
Greg Arehart's Avatar
Steve,
I believe that there was a thread here that Craig responded to a couple years back that indicated the props were pretty much sealed up with epoxy (even the center, that looks more like wood) and thus not responsive to humidity swings. But you might give him a call and ask. My prop (2 years old now) has never needed retorquing (I've tested it a couple times in addition to at 2 annuals).
Greg
Greg Arehart
N 7965A
Old 02-09-2015, 04:28 PM
jrs14855 jrs14855 is offline
Default Catto
Originally Posted by Greg Arehart View Post
Steve,
Greg
That is my understanding also but in addition Catto is now bonding and aluminum plate to the aft side of the "hub", I believe he has been doing this for some time. But check with Catto.
Old 02-09-2015, 07:37 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
I checked mine at inspection time in December and all the bolts took 1/2 - 3/4 of a turn... We're in a semi desert...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 02-09-2015, 07:42 PM
Steve,
Greg
I've heard both yes it's needed and no it's not needed secondhand, so I may need to hear it from Craig himself.
The pic below shows two of my washers from a retorque today, right at the high humidity point of the year. The last time I retorqued was at the height of the dry season in July. The washer on the left shows the forward face, the washer on the right, the aft face. My Saber crush plate has a slight chamfer on the bolt holes and on the washers you can see where the washers took on that chamfered form. (The washers are standard cad-plated 7/16"; upon inspection, the bolts look just fine.)
When I last retorqued in the summer my washers looked just fine, but that's probably because the prop had dried out and shrunk since the previous January's retorque.
Based on today's discoveries, and to get a start on answering my own question, it appears that I definitely need to shift my retorques to around October and March and/or shift to retorquing 4 times per year.
Steve M.
Ellensburg WA
Old 02-09-2015, 07:52 PM
That's interesting Ron. Summerland has pretty much the exact same climate as Ellensburg. Maybe you have a different generation/better sealed prop? Mine's 2009, and I can definitely see wood in the interior crankshaft hole, so I don't think it is sealed.
Steve M.
Ellensburg WA
Old 02-09-2015, 08:48 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I've been flying my 3 blade vintage 2005 Catto prop since 2006. I usually check it a couple times a year. It's always maintained it's proper torque tolerance.
I live in Florida.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 02-09-2015, 08:53 PM
jjconstant's Avatar
jjconstant jjconstant is offline
We had Marc Zeitlin do a talk at Livermore Chapter 663 and he is now a big believer in the belleville washer approach to wood prop installations.
http://www.vansairforce.com/communit...+washers+props
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
Old 02-09-2015, 09:28 PM
SHIPCHIEF SHIPCHIEF is offline
I have a 1980'ish 5 lamination Ted Hendrickson 68x68 on my T-18. It would be a worst case scenario for a prop (only 5 wood layers, urethane varnish, fiberglass over tips only) . I live in Western Washington, which is about the best climate for a wood prop if you don't abuse it in the rain.
I re-torque it during condition inspection, it takes little to nothing. I've had the prop off a few times, and no significant crushing was observed. The fit over the drive lugs and the bolts thru the wood are still very tight. It has a little over 400 hours in service. I think it has always been hangared.
I'm on my second CATTO, both seem to hold torque well, but I have not had them long enough to add anything to the conversation.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 02-09-2015, 10:06 PM
wjb's Avatar
wjb wjb is offline
+1 on this .. very interesting presentation. His prop departed the aircraft at 13,000 ft (with minimal damage to the plane). Safe, though very quiet landing. The plane was originally based on the east coast, then came to CA where the prop dried and shrunk just a bit. check it out.
http://www.cozybuilders.org/Prop_Bol...her/index.html
Bill Bencze
