Old 02-08-2015, 06:59 PM
macrafic's Avatar
macrafic macrafic is offline
Default Tip-up Canopy Clearance
How much room below the top of the subpanel needs to be kept clear of avionic components/structure so that they do not interfere with the tilt canopy in a closed position (RV-7A)?
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 02-08-2015, 07:01 PM
bruceh's Avatar
bruceh bruceh is offline
Enough for the canopy frame to close. About an inch and a half, if I recall.
Bruce Hill
2020 VAF donator
Old 02-08-2015, 10:46 PM
RV7A Flyer's Avatar
I dodged this bullet *just barely* when I installed my avionics. Forgot about the forward part of the canopy with the stiffener pieces, and damned if the topmost component (GMA 340 audio panel) was just a hair too close. Changing a few rivets to flush Cherry-Max rivets gave it just enough clearance (it was the cable connectors which were interfering with the stiffener), but I almost had to cut a new panel. This was *after* having the panel, including the upper panel stiffener angle and several angle pieces for the avionics racks all riveted in place, nicely powdercoated. Would have been a PITA to redo it all.
A 3D CAD program with keep-out zones would have been nice during panel layout .
Old 02-09-2015, 07:15 AM
TX7A TX7A is offline
As mentioned, watch out for the canopy frame where it extends down along the sub panel. Also, watch out for the stiffener assembly as they angle down toward the front. As a matter of fact, when I started planning my panel I made a cardboard mock-up of the stiffeners to see what space they would consume. I have a Dynon D100 & D120 & I wanted them up as high as I could get them without having an interference issue. Study it carefully.
Sam
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 02-09-2015, 09:00 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up Mock-up
A mock-up done in acrylic or plexi before and CAD/CAM cutting is worth it's weight in gold for a tip-up...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-09-2015, 09:52 AM
bruceh's Avatar
Here is a photo that will give you an idea about how much room the canopy frame takes up along the top of the subpanel.
Bruce Hill
2020 VAF donator
