02-05-2015, 10:16 PM
Weight and Balance help please
I've downloaded the Aviation W&B app from iTunes. It has great reviews! I'd like to put the numbers in for my 7A but find I'm getting confused. Would appreciate any help.
Here is snapshot of the sample graph they give. I'm suppose to use it as an example to input the numbers for my airplane. Some of the points I can get but points 1, 2 and 3 I'm not sure how to come up with. The CG range for the 7A according to vans is 78.7-86.82. The empty weight CG for my aircraft is 81.52. Are points 1 and 2 suppose to be 78.7 or my aircrafts empty weight CG of 81.52? Also, I know the Weight at point 1 is my aircrafts empty weight but where does weight for point 2 come from.... The weight for point 3 is the max gross weight but how do you come up with the ARM to input. Point 4 max gross wt and most aft CG from vans numbers and point 5 empty wt and vans aft most CG??? Thanks in advance for helping me clear my head!!!!
Paul Gray
Foley, Alabama
N729PG..... 450+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
02-05-2015, 11:25 PM
The graph you show is very common, where a more forward limit is allowed at lower weights. However, Vans does not allow that. So use the forward cg limit (78.7") for points 1, 2, and 3. Point 1's weight is your empty weight; point 3's weight is your gross weight. For point 2 just pick a weight anywhere between empty and gross. Point 4 is maximum aft limit (86.82") and gross weight. Point 5 is 86.82" and your empty weight.
02-19-2015, 08:25 AM
Moderator, Asst. Line Boy
Bob, Why not just delete point 2?
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
02-19-2015, 08:35 AM
Here is a link to a spreadsheet style W&B for an RV7A I found somewhere (maybe here). Note the rectangle shape of the load range.
https://drive.google.com/file/d/0B9G...ew?usp=sharing
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
02-19-2015, 11:05 AM
Because I have no idea what the software would do with a missing data point.
02-19-2015, 05:10 PM
Then make point 2 and point 3 the same value. The sw should be OK with that.
Update, Looking at the screen in your first post, it looks like the "extra" points are just set to "0,0", just like Point 6.
Make point 5 0,0 and just use your four points in the definition.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
02-19-2015, 05:21 PM
Senior Curmudgeon
Advanced Flight Systems has a really nice W/B program built into their units. At one time it was offered on the I tunes store, but I seem to recall it had a bug and was removed. I do not know if it was ever fixed and offered again, but if so, I would surely buy it for our Ipad. https://itunes.apple.com/us/app/weig...430996589?mt=8
Rob??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-21-2015, 06:33 AM
That is just a sample. Depending upon the envelope for your aircraft you may only have 4 points or 6 or more. Dependent on your aircraft.
Go to the Airplane Template Library and there is already a 7A W&B to download. You will just change the weights for your aircraft.
