  #11
Old 02-06-2015, 01:44 PM
sapeloson's Avatar
sapeloson sapeloson is offline
Default Congrats!
Gorgeous Plane!
RV-8
Phase 1 Flight Testing
Garmin IFR by Stein
Lycoming IO-360 (180HP)
MT 3 Blade CS
N84TH / Registered and GA sales tax paid! $@&!;:?)(!
N3159F C-182 @ KJES
Old 02-06-2015, 02:21 PM
gator gator is offline
Default A real work of art
Beauty from a distance is one thing but you should see her up close. I've seen a lot of RVs but this has to be one of the BEST!
Congratations Tom. It's a winner...
Old 02-06-2015, 02:31 PM
designrs's Avatar
designrs designrs is offline
Congrats Tom... Pardon my not knowing your history... just learned of you now. We don't want to be pushing you too hard! Where are you on the RV-8 piloting? Are you stepping up to the performance of your new bird? Or do you have a lot of time in similar performance aircraft?
Old 02-06-2015, 03:39 PM
vfrazier's Avatar
vfrazier vfrazier is offline
I love the scheme. Very nice.
One question though... why are the Hartzell stickers not in the center of the prop chord? There must be a reason.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 02-06-2015, 05:01 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
I had the honor of witnessing that 1st flight. I can testify it is a BEAUTIFUL screamer!
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 02-06-2015, 05:51 PM
s10sakota's Avatar
s10sakota s10sakota is offline
Unbelievable! That is the most beautiful airplane I've ever seen!
What's not posted in this thread but is on his Photobucket site is a pic of the panel. Nicest, most beautiful panel I've ever seen!
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 02-06-2015, 06:48 PM
g zero g zero is offline
Default 666TA
Wow ! Made the front page .
Triple Six is a slow built kit with a modified Sam James cowl ,Plenum and wheel pants , Todds tinted canopy with my own skirts . I painted (myself ) with DuPont Croma Base/Clear , Ford Fusion grey , silver,white and Dodge Charger Performace red , cleared ,sanded , cleared again sanded thru 5000 grit and buffed . It has the same design on the bottom of the wings and tail along with a canopy and wing walk painted on the bottom ( as seen on a A-10 )
Engine is from Ly-con , Angle Valve Io-360 , forward facing Bendix FI , Bendix Mags , 10:1 ceramic coated Pistons, flowed heads .etc....... AWI 4 into 1 exhaust and a custom ducted 17 row oil cooler , Half Raven inverted system . Prop is a 74" F7666 blade Hartzell ( Mid Fla Propellor applied the decals ????)
It has a 4 gallon smoke tank in the rear battery location . The 3.2 lb battery is mounted behind the instrument panel ( Battery Tender Brand ) along with the starter solenoid and amp shunt .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 02-06-2015, 06:51 PM
GLPalinkas's Avatar
Big time congrats Tom...
Stay safe in phase 1 and keep us posted.
Venice, Fl
Old 02-06-2015, 07:05 PM
Default 666
It weighs just under 1100. Cg is at the forward end , for flight testing I have 3-1/2 gallons of smoke oil to get me in the envelope .
Performace is unbelievable , our class D is 1500 feet , I was out of the airspace tonight at mid field !
Temps are great , front cylinders a little cold . Tonight in economy cruise I saw 160 knots ,300 degree CHT ,1300 EGT , 7.1 gpm at 23/23 @ 3000 (DA 2400 )
Too bumpy to try some speed .
The plane came out and performed better than I ever anticipated. It took about 2800 hours ( airframe took less than 1000 ) . Most of my airtime is in open cockpit Bi Planes , this is the first 8 I've flown , got some stick time in a 9 TW ( thanks Tony ) and a 7 ( thanks Charlie ) and I've bounced a Thorp many times ( Doug !)
I Look Forward flying this weekend , great forecast and $3.38 fuel !
Rv8
N 666 TA
2017 donation paid
Old 02-06-2015, 07:30 PM
apkp777's Avatar
apkp777 apkp777 is offline
Tom, one of the finest examples of an RV I have ever seen. I look forward to riding along some time soon.
Tony Phillips
N524AP, RV 9 (tail wheel)
