  #11
Old 02-04-2015, 06:08 PM
Relentless's Avatar
Relentless Relentless is offline
Originally Posted by BobTurner View Post
I know you said "about" but it is pretty near impossible to get a 14% (175/153) speed increase out of a 17% (305/260) power increase, unless there are other things (drag reduction, etc) going on. As previously noted the weight cannot be 130 lbs lower with a 40 lb lighter engine. A 6% speed increase would be more in line with the laws of physics. Note the other numbers in the chart suggest that a 11% power increase (260/235) gives a 4% (153/147) speed increase, more in line with the usual "speed varies as the cube root of power" rule.
thank you for the detailed analysis, I'll update my chart and get to work proving it out….The R540 normally aspirated should be around 315 based on our testing and conversion of stock 360 at 210hp…..
I am RELENTLESS...
R Series Engine Information
Rv8 ACE-360r
Nemesis NXT (building ACE-750r)
Relentless's Avatar
Originally Posted by Aiki_Aviator View Post
What is the Hp WITHOUT supercharger?
Seems like it is 300 WITH Supercharger.
315 is best guess for normally aspirated R540?..
I am RELENTLESS...
Rv8 ACE-360r
Old 02-04-2015, 06:19 PM
Relentless's Avatar
Default Fined tuned with the help of Vansairforce Community
I am RELENTLESS...
Rv8 ACE-360r
Old 02-04-2015, 08:24 PM
majuro15's Avatar
majuro15 majuro15 is offline
Kevin, thanks for the time today to chat on the phone. I really appreciate the info and advice. I look forward to seeing some numbers from RV-10's with your R series engine hung on the front!
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
Old 02-04-2015, 09:42 PM
Tassie Tassie is offline
Default R540 engine break in
Kevin,
What will be the break-in procedures for the R540? Even without wheel fairings, it might get a bit "exciting" in an RV-10 first flight scenario if there's 315 horses up front that have to be run at 75%...
Adrian Port
RV-10 emp done, wings 90%, fuse 90%, cabin top DONE!
www.tasrv10.com
Old 02-05-2015, 05:40 AM
BillL BillL is offline
Default Fuel? SFC? Did I miss it?
I still have not seen (or I missed) reports on the specific fuel consumption numbers for the AX50 heads on an 3XX engine.
That was supposed to be a big benefit of the head/cylinder packs. Better cooling, better combustion, better, lean limit, higher Cr, less detonation, and then - - better SFC. That could go a long way in paying for the new technology.
Bill
RV-7
Lord Kelvin:
Old 02-05-2015, 07:42 AM
Palamedes's Avatar
Palamedes Palamedes is offline
Great engine if all this pans out =)
Quick off topic;
Whats the plane in the background of the hero image on their website?; http://www.titanengine.com/rseries/
Jason Ellis
RV-10 - Still pluggin away at it.
Blairsville, GA
Youtube Channel and RV-10 Build Log
Old 02-05-2015, 07:55 AM
johngoodman's Avatar
johngoodman johngoodman is offline
Originally Posted by togaflyer View Post
Will the current RV 10 upper and lower cowling work without modifications to them and what is the expected pricing.
Did you ever get an answer?
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 02-05-2015, 08:30 AM
Quick off topic;
Jason - that airplane is "Relentless", the Reno racer. Note the striking similarity to the name of the Original Poster. Yes, they are connected, very intimately.
Old 02-05-2015, 08:38 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
As already stated, it is named Rentless------the model is an Nemesis NXT.
http://en.wikipedia.org/wiki/Sharp_Nemesis_NXT
The original Nemesis was a formula one, Jon Sharpe got tired of winning every race he entered , so he designed the NXT to compete in the new sport category at Reno.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
