Old 02-03-2015, 08:44 PM
txshan130 txshan130 is offline
Default Panel lettering template files
Hi -
I just ordered DecalPro to fix up some lettering on my panel....does anyone have a Word or PDF file they wouldn't mind sharing and emailing to me? I realize some of the wording may change but it's probably pretty close and I was hoping to save a little time using someone's file...thanks in advance!
PM me and I will send you my email.
Brian Shannon
Katy, TX
RV6 N7463B
Old 02-03-2015, 09:15 PM
Hey Brian,
Here's what I used. Not a Word doc, so I just cut and pasted. I've repeated everything on the doc, because I went through SteinAir and they'll print whatever you can cram on a page for $25.
Panel decals
water slide type, black with clear background
Arial regular, 10-point type
MASTER MASTER
ALTERNATOR ALTERNATOR
EFIS EFIS
AVIONICS AVIONICS
NAV LIGHTS NAV LIGHTS
STROBE LIGHTS STROBE LIGHTS
LANDING LIGHT LANDING LIGHT
CABIN LIGHTS CABIN LIGHTS
BOOST PUMP BOOST PUMP
ALTERNATOR BREAKER ALTERNATOR BREAKER
ELEVATOR TRIM UP DOWN ELEVATOR TRIM UP DOWN
FLAPS UP DOWN FLAPS UP DOWN
USB USB
ELT ELT
AUDIO INPUT AUDIO INPUT
THROTTLE THROTTLE THROTTLE
MIXTURE MIXTURE MIXTURE
CABIN HEAT CABIN HEAT
OIL PRESSURE OIL PRESSURE
CYLINDER HEAD TEMPERATURE CYLINDER HEAD TEMPERATURE
OFF OFF OFF OFF OFF OFF
????-?? OFF ??-????
???????????????? OFF ????????????????
__________________________________________________ ___________________________
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 02-04-2015, 11:33 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default check with Stein
I think it's closer to $55 a sheet as of last month or so. I just asked recently as I consider my own options.
Old 02-04-2015, 11:52 AM
flyboy1963's Avatar
Default fonts etc.
If you are tight for space, consider the condensed version of the same font ( typeface), or use title case....capital first letter, then lower case. the small letters are just as legible, and will take up less space.
for highway signs, I use upper & lower case on everything, due to the improved legibility & recognition time.
funny eh? the auto industry has gone to a lot of symbology on their panels, ( some good, some not!) but not so much aircraft.
Probably some European kitplane has this, and I just haven't noticed yet.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 02-04-2015, 06:30 PM
Charles in SC Charles in SC is offline
I bought a BEE 3 label maker. It has been worth it's weight in gold! I really like that it will print shrink tubing so I can label wires. I made the labels for my panel as well.
RV 7
Old 02-05-2015, 08:51 AM
philb philb is offline
from Stein, couple weeks ago:
Yes we can make water slide decals for you. The cost is $25 per 8 ? x 11 sheet. Please send me a Microsoft Word document just as you want it printed. Please leave a 1? margin on all sides of the sheet. Tell us if you want the sheet printed in black or white.
Phil Barnette
Bountiful, UT
RV-10 finishing
Phil Barnette
RV-10, Finishing
KBTF (Bountiful, Utah)
Feeding Doug and family in 2017
Old 02-05-2015, 11:57 AM
Bill Boyd's Avatar
Default Very good
...but I know I was on the phone with the man himself when he told me 25 and then corrected himself to 55 on the decal sheet.
Regardless, UPS makes way more profit from my dozens of SteinAir orders than Stein does If only I could know ahead of time all the tiny bits I was going to need for this panel project, I'd save beaucoup shipping.
Old 02-05-2015, 09:11 PM
Thanks again everyone...I think I almost have what I need but keep 'em coming! I will be compiling everything that I receive and making a master document for others to use in the future. If anyone reads this thread later on and is in need of panel lettering templates, PM me and I'll pass on what I have.
Brian Shannon
Katy, TX
RV6 N7463B
Old 02-06-2015, 05:41 AM
BillL BillL is offline
Default Group Contract Available?
Originally Posted by Bill Boyd View Post
<snip > If only I could know ahead of time all the tiny bits I was going to need for this panel project, I'd save beaucoup shipping.
Amen, brother!!
I try to keep shipping to less than 20% of the product. I think the RV world should have a UPS Commercial account for a hefty discount!! I am thinking a "Group Contract"
Bill
RV-7
Lord Kelvin:
