I recently purchased a Smoke System Helper system from Marvin. His system and support are excellent. I am including the pictures of my installation. I went for the rear baggage compartment system due to a forward CG in my -8. I had to take the interior out to run the electric and supply hose. The plastic grommets were expensive to purchase individually so I purchased 100 for $12.00. if you need any just call I used 6. I used a 7.5 amp circuit breaker with a toggle switch for long use and a Momentary Switch for intermitting use. I used a cube relay for the power to the switches. The electric plug connector will be used for a rear seat power outlet when the smoke system is not installed. Hydraulic fitting is recommended because it seals both ends when disconnected.
http://s1291.photobucket.com/user/Lo...lideshow/smoke
If there are any questions. Feel free to email/call
Loeds
Marvin Homsley
Smoke-System Helper
419-360-7414
www.smoke-system-helper.com
