Old 01-31-2015, 02:45 PM
macrafic's Avatar
macrafic macrafic is offline
Default Aircraft Axis References
When considering the installation of a unit such as the Garmin GSU 73, which needs to be installed relative to the aircraft axis, what would you consider to be the lateral and longitudinal reference of the aircraft? I am thinking that the longerons (tail to nose) represent the longitudinal axis, while a level set across the longerons (right to left) represents the lateral axis. Can somebody confirm?
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 01-31-2015, 05:15 PM
g zero g zero is offline
Default Axis
Depends if you plan to fly pole to pole or around the equator .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 01-31-2015, 05:53 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default You have it right
Long. vs lateral axis --- you got it!
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
