The MIT data was taken at lambda=1.0 . There would be complete burn here due to burn rate (heat release). At a more fuel rich mixture, it is possible to get residual burning at exhaust valve opening. Just a technical point, but that is probably not affecting the OP's situation. Additionally, the port shape, combustion chamber and compression ratio affects the burn rate. A swirl imparted to the cylinder charge would increase burn rate/heat release rate. Tumble with a 4 valve configuration would also have an effect. Swirl would reduce best torque timing advance, but also increase heat rejection to cylinder, piston and head.
I was told on some Conti turbo charged engines, the peak exhaust temp occurred 12-14 inches from the port. They had to move the temp probe for that engine.
Interesting data here, an investigation would be some fun.
Bill
RV-7
Lord Kelvin:
