Old 01-29-2015, 08:41 PM
flyboy1963's Avatar
Default CHT & - which cylinder is the hottest one?
I get the feeling I need more instrumentation....is one CHT gauge useful?
If so, it would seem that you'd want it on the one that typically runs hot....so is there a trend; on an 0-320, is one usually hottest?
I have my single EGT on #4, does the CHT have to be on that one to show the relationship when leaning etc?
...appreciate any advice.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 01-29-2015, 08:43 PM
SHIPCHIEF SHIPCHIEF is offline
Mine is on #3, the rear one on the right side. I 'think' that's the traditional location....
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 01-29-2015, 09:33 PM
Bavafa Bavafa is online now
Same as mine, although only be a few degrees only.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-29-2015, 11:57 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Since you are carbed there's no way to know without full instrumentation. The fuel distribution can get pretty screwy depending on where the throttle is. For me, full throttle makes 1-2 hot. Back off a bit and 3-4 will get the hottest. Then when I lean things change again. This is where IO's, assuming the cylinders get flow matched, have a big advantage.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 01-30-2015, 08:44 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Default cyl # 1
is my hottest, typical around +25 F.
Lycoming O-360-A1A
EI UBG-16
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 01-30-2015, 09:17 AM
jjconstant's Avatar
jjconstant jjconstant is offline
I think your first observation was right...you need instrumentation on all cylinders, especially if this is a new engine. I think the single channel instruments were probably good enough for certified planes where they were all the same and they knew what the cooling situation was. Are the new certified planes shipping with single channel or all cylinder instrumentation?
With ours, even the same engine and same air frame model have big cooling variations from build to build. In mine, not only does throttle and mixture change which is hottest, attitude and airspeed change it as well. You have to pick the condition that you are aiming to optimize. Without instrumentation, you're just guessing.
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
Old 01-30-2015, 09:33 AM
RV6_flyer's Avatar
IMHO, you need all cylinders instrumented even if it is only a single channel instrument with a switch to switch between cylinders.
My O-320 RV-6 has been flying over 17-years and 1,954 hours.
At one point in time, I had Superior Investment cast cylinders. #2 was coldest cylinder all the time and hottest would switch between 3 and 4 depending on altitude and power settings.
Switched to ECI Titan through hardened steel cylinders. In climb, #2 is now my hottest cylinder with typically 3 or 4 when in cruise.
My experience with my airplane has different cylinders hottest at different operating parameters.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-30-2015, 10:12 AM
Same here approaching TBO on the original probe. The lesser I know the better I sleep
Old 01-30-2015, 10:36 AM
bruceh's Avatar
bruceh bruceh is offline
I always download the flight data logs from the Dynon Skyview and have a look at how temps and such are doing. The hottest cylinder will move around the engine depending on whether I am climbing or straight and level, or with or without the oil cooler shutter closed. All of the cylinders stay pretty close to one another - within 20 to 25 degrees max. Having all cylinders instrumented makes it very easy to diagnose any issues. I have over time cut down some of the air dams in front of the forward cylinders and surprisingly, they haven't had a huge affect in temps, but more in the balance of temps from front to rear.
Bruce Hill
2020 VAF donator
Old 01-30-2015, 11:21 AM
flyboy1963's Avatar
Default good news, bad news...
Ok, great responses as always guys....I think my engine has about 270 hrs. might have one new cylinder ( 100 less hours)
sounds like if I only am worried about cooking something in a climb on a hot day, one might do......
but to 'manage' things, obviously reading all the conditions is needed.
for now, I'm in ostrich mode, happily driving along, oblivious.....
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
