  #11
Old 01-30-2015, 06:26 PM
BillL BillL is offline
Originally Posted by Fly2KiteSurf View Post
Guess I should have clarified. Thanks for pointing that out.....
I am not interested in a larger oil cooler. I just don't like the weight and stress up on the cooling baffles and repairing cracks and patches, etc...
I can fix the current cracks on the -7 I just purchased, or relocate the oil cooler to the firewall?
Thought about using the 10 or 14 oil cooler bracket if it fits (or similar bracket if available) on the firewall of my -7, but use the standard smaller oil cooler.
Hope that clarifies things.
Advise appreciated.
I am building a 7. A 180hp, parallel valve, no cooling jet engine. I considered seriously whether the baffles could be made durable. After researching for hours and days, I concluded that the three things would achieve that (durability), an angle along the LR corner, a stiffener from the top left corner of the cooler angling down to the head screw, and a stiffener from the upper right corner of the cooler forward to the engine case. The first two stiffeners attach to the two screws on the #4 head. The third stiffener addresses the wagging, pivoting, along the corner. Paul Dye replaced his baffles and documented the process here.
Concluding they will be durable, I decided to mount mine to the baffles in the standard manner. YMMV
Positives for the remote mount are air flow control and any risk of baffle cracks. The negatives are, careful attention must be paid to ensure adequate airflow, and the pain of a modified installation. Although there are many well made successful installations, some are not.
I am admittedly jaded being off plan on too many items already and not wanting (needing) to tackle this one.
So, I would advise (verb) you to appropriately beef up the baffles. That is my advice (the noun). Either way can be durable and cool.
Bill
RV-7
Lord Kelvin:
Old 05-24-2016, 06:51 PM
Tbone's Avatar
Tbone Tbone is offline
3mxc,
Do you have any pictures of your oil cooler mounted with the engine and mount affixed to firewall. Would like to see the clearance allowed.
___________
Terry
RV7
XP IO360
Old 05-24-2016, 06:58 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default IO390
I'm putting an IO390 on the new 7. I mounted the engine then held everything in place to get clearances. Removed the engine and put everything on the firewall. Here's a pic of the progress so far. The engines goes back on permanently after I get back from vacation in a couple of weeks.
[IMG][/IMG]
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 05-24-2016, 07:21 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I share your aversion to baffle mounted coolers. I recommend however to not use the RV-10 firewall bracket. For me it creates unnecessary airflow backpressure from the multiple changes in airflow direction. On my RV-10 the cooler is mounted horizontally and has a simple plenum on top to connect the scat hose.
Use the cooler you have (unless you have reason not to). Make a simple bracket out of .063 aluminum angle, feed it with a 3" hose off the baffle and use a butterfly valve.
Carl
Old 05-24-2016, 08:20 PM
DaveO DaveO is offline
When i built my 7A I mounted the oil cooler on the firewall using a home made bracket. 3 inch hose. I did not use RV-10 cooler. Worked good.
Dave
Old 05-25-2016, 03:29 AM
RViter RViter is offline
Default Oil Cooler - orientation?
Interesting Pic with the Vertical Power PPS - which doesn't seem to be 'available' anywhere on their web site ... ;-o
Question - Your oil cooler is mounted with BOTH inlet and outlet on the topside, and I was under the impression that generally this would be inlet on the LOWER, and outlet on the UPPER fittings, respectively. The concept of thermal rise to engine return line consistent with that. Of course, the forced flow may negate any such thermal flow factors. Maybe?
Very shiny stainless FW!!
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 05-25-2016, 05:29 AM
Honestly, I am not sure why the locations would make a difference in this case. Locating the inlet on the lower side makes good thermodynamic sense if baffle mounted as the hotter oil would engage with the hotter air off the head on the lower side. That would leave the delta-T of the top side still able to remove more heat from the oil. In this case, it is not clear if the air coming in has any temperature gradient across the face to benefit from a port location change.
This is certainly open to discussion.
Bill
RV-7
Lord Kelvin:
Old 05-25-2016, 12:13 PM
Evolution10 Evolution10 is offline
Mike at Avia comp (http://www.aviacompinternational.com) manufactures the butterfly as well as many other interesting items. He also makes the stainless heater boxes. He probably sells to ACS, AVERY, ETC...
