Old 01-26-2015, 09:05 PM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default Soldering to aluminum plate
I wanted to solder a wire to a piece of .020 aluminum. I did a test solder on some scrap aluminum. Scuffed up (one side on test piece) and cleaned with alcohol. I could not get the soldier to flow. Is there a trick to soldering to aluminum plate? Could it be I just need to get more heat into the aluminum or is something else going on here?
Bob
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 01-26-2015, 09:22 PM
vlittle's Avatar
vlittle vlittle is offline
Aluminum is not solderable using normal techniques. You'll need to use a mechanical fastener or some fancy brazing method that I never mastered.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
eddieseve eddieseve is offline
Hi Bob
You might find this helpful
http://www.instructables.com/id/How-to-weld-aluminum/
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 01-26-2015, 09:42 PM
bobmarkert's Avatar
Default thanks
thanks, plan B
Bob Markert
Littleton, CO KBJC
2019 dues paid
Old 01-27-2015, 07:14 AM
DanH's Avatar
DanH DanH is offline
I've soldered aluminum screen into a brass shell with Harris AL500. Works very well.
http://www.harrisproductsgroup.com/e...older-500.aspx
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-27-2015, 10:27 PM
wjb's Avatar
wjb wjb is offline
Soldering to aluminum with standard tin/lead solder won't work well at all. The typical way to electrically bond to aluminum is to alodine the surface and use bolt/nut and ring terminal to make a good electro-mechanical bond to the aluminum (see MIL-DTL-5541F for more detail). The alodine minimizes the possibility of aluminum corrosion between the dissimilar metals of the aluminum and ring terminal (which usually is copper with a tin or tin/lead plate)
Bill Bencze
Old 01-27-2015, 11:01 PM
larosta larosta is offline
Default Conductive Epoxy
YOu may want to look at an electrically conductive epoxy. Probably not a candidate for high current but a good option for shielding connections and antenna ground planes. McMaster Carr stocks it as do several of the electronics supply houses. Do a search for "electrically conductive epoxy"
It is expensive but can be a good solution to difficult problems.
Prep, prep, prep!
LOCTITE ABLESTIK 3888
Old 01-27-2015, 11:02 PM
lr172 lr172 is offline
They make a special solder for aluminum, but I have never been able to make it work. I believe that it won't hold the heat. AL is a bit** I have successfully stick welded it, but never solder. Brazing may work but will require a oxy acetylene torch.
Larry
Old 01-28-2015, 07:03 AM
DaleB's Avatar
DaleB DaleB is offline
You can do it, it just takes a different technique. I've soldered a lot of wire to AL battery cases and the occasional sheet.
You need to use an iron or gun with enough wattage to heat the AL, which may be difficult due to the large mass/area that needs heating. AL conducts heat really well, meaning you're trying to solder to basically a big heat sink. Also, solder will stick to AL but not to aluminum oxide, which forms almost instantly when it's exposed to air. Clean it, scuff it, doesn't matter, by the time you get the solder to it, it's oxide coated.
The solution is to scuff the surface while it's covered from exposure to air. I have read of people using oil to coat the area to be soldered. haven't tried that, although it sounds reasonable. I have used an iron with a sharp or rough tip to melt a puddle of solder, then scrape away the area under the solder puddle. When you rub away the oxide the solder will stick. Once that happens you can get a good joint with the wire.
That said, when I need to attach a wire to a piece of sheet metal it's usually time for a ring lug, screw and a coupe of washers.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 01-28-2015, 08:01 AM
JDA_BTR JDA_BTR is offline
A small screw/bolt with a lug washer is the best way; Noalox between the Al and the washer will minimize corrosion - that's the ham radio way anyway.... I don't know about noalox on an airplane maybe someone can tell me.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
https://www.atkinsonurology.com
