Old 01-26-2015, 02:47 PM
moll780 moll780 is offline
Default oil cooler thread sealant.
What sealant is the best for the an fittings for the oil cooler?
thanks
--2008 RV-9A
Austin TX
Old 01-26-2015, 05:36 PM
krw5927 krw5927 is offline
thanks
You'll hear a lot of answers here from Loctite 567 to TiteSeal to....
I like Loctite 567. Do NOT use fuel lube.
Kurt W.
RV9A
FLYING!!!
Old 01-26-2015, 06:19 PM
drakerv drakerv is offline
RectorSeal
Old 01-26-2015, 06:22 PM
NYTOM NYTOM is offline
I probably wouldn't use it myself but just wondering, why not fuel lube?
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 01-26-2015, 06:31 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
+ 1 Loctite 567... Fuel lube is not a sealant.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-26-2015, 06:36 PM
jthocker's Avatar
jthocker jthocker is offline
You will find many people that swear by the stuff, you will find many people that replaced it with something else, that DID NOT leak!
loctite 561 = no leaks
loctite 567 = no leaks
EZ-turn / Fuellube = easy removal of fitting to apply THREAD Sealant!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 01-26-2015, 07:04 PM
deek deek is offline
I use Bakerseal
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 01-26-2015, 09:39 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Default Permatex#2
I think i read somewhere here in the forum that Permatex #2 was acceptable for the steel fittings into the oil cooler? Is this Not the case?
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 01-26-2015, 10:04 PM
chaskuss chaskuss is offline
Default My vote
The link below will direct you to my favorite pipe thread sealant. See
http://www.permatex.com/products-2/p...th-ptfe-detail
Charlie
Old 01-27-2015, 07:01 AM
thanks all for the quick replies!
567 on the way!
--2008 RV-9A
Austin TX
