Old 01-21-2015, 05:44 PM
Saville's Avatar
Saville Saville is offline
Default O&VO-360 SER - what kind of engine is this?
What do the Lycoming designations mean when you see:
O&VO-360 SER
Thanks!
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 01-21-2015, 07:24 PM
Jesse's Avatar
Jesse Jesse is offline
The V is for vertical. It's for a helicopter.
Jesse Saint
Old 01-21-2015, 07:37 PM
Saville's Avatar
And the "SER".....what does that mean?
I'm assuming that since it says "O" that it's carbed.
Flying RV-8 N880BC
Old 01-21-2015, 07:39 PM
Jesse's Avatar
Most likely Ser short for Series. Yes, it would be carb'ed. It would be IVO for injected.
Jesse Saint
Old 01-21-2015, 08:01 PM
Steve Barnes Steve Barnes is offline
Default What does "O" mean?
"0" means opposed.
Steve
Old 01-21-2015, 08:05 PM
Jesse's Avatar
Correct. The O doesn't stand for Carb, but the lack of an I means it's not injected.
http://hhh.gavilan.edu/hspenner/Main...Helicopter.pdf
Jesse Saint
Old 01-22-2015, 06:16 AM
David Z David Z is offline
The O actually means Horizontally Opposed, relating the the cylinder configuration. Other options are V-####, for V engines like V-1650, or R-### for Radial engines. So VO-### means "vertically mounted opposed". Carburetors are assumed unless an "I" specifies fuel injection.
Of course a manufacturer can name an engine anything he wants. The WAM-120 is example of this, as it's not called the TI?-### for Turbocharged, fuel Injected, and I don't know what nomenclature they use for inline. Inline engines are typically European where they don't follow this convention.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 01-22-2015, 08:26 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by David Z View Post
......Inline engines are typically European where they don't follow this convention.
...and Lycoming didn't have their naming convention in place when they produced straight-8 engines for some of the exotic cars of the 30's, such as the Cord.
Cord owned Lycoming at the time...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-26-2015, 03:05 PM
Saville's Avatar
If that's the case, what are they telling you when they say "Series"?
thanks
Flying RV-8 N880BC
Old 01-26-2015, 04:21 PM
Jesse's Avatar
For example, an O-360 series would of include the -A1A, -A2A, A1B, -A4M, etc. There are different variations in the same series.
Jesse Saint
