Old 01-21-2015, 12:56 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Default Dynon SkyView 12.0 Now Available
Dynon Avionics is excited to announce that SkyView software 12 is now available. This update adds features most often requested by pilots, including Autopilot Auto-Trim,* OBS mode on the moving map, an optional in air magnetic calibration routine, and over 40 other features and improvements. SkyView 12 is available as a free downloadable update for all Dynon SkyView customers.
Autopilot Auto-Trim
The SkyView Autopilot can now automatically keep the the aircraft in trim while under autopilot control, eliminating the need for the pilot to manually actuate their trim to satisfy the Autopilot?s built-in trim advice. This feature requires that the aircraft has an SV-AP-PANEL and is using its integrated trim controller for electric trim servo actuation. Auto-Trim can be configured on pitch and/or roll axes.
OBS Mode
OBS Mode allows pilots easily set and adjust an inbound course to any navigable point on the map. That inbound course may then be easily adjusted with the HSI CRS knob, similar to how one chooses a VOR radial. This feature is useful to approach an airport from a specific direction, for example, without having to create a second waypoint to create a full flight plan leg. Pilots can essentially treat any point on the map as a ?virtual VOR?.
Optional In-Air Magnetic Calibration
Pilots can now perform an optional in-flight magnetic heading calibration routine in addition to the existing ground calibration. Pilots that opt to perform this calibration are likely to see improved magnetic heading performance during flight maneuvers. It can also improve heading performance in aircraft where the ADAHRS is subject to localized magnetic interference.
Customizable Aircraft Icons
The aircraft icon displayed on the Map and in the HSI can be changed to one of over a dozen types of aircraft.
40+ More Improvements
SkyView 12 also contains over 40 more improvements and fixes. See the full list here.
As always, updated documentation is available, with red-line versions that capture the changes since version 10. There?s a full set of release notes that detail every feature, improvement, and bug fix.
SkyView 12.0 can be downloaded from the Dynon Avionics website.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 01-21-2015, 03:23 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
I have been flying the auto-trim for a couple of months testing it……it works very well and the depiction of which servo is running and in what direction is very cool indeed.
PLEASE NOTE : The runaway trim protection feather still applies though, so if you pull back a heap of power on approach, and the trim speed is in its slow speed range, there is a chance your trim time will hit the runaway trim limit. This will bring up a TRIM FLAG like before, simply press your trim to reactivate and it will continue trimming.
This makes it one heck of a good system….. I have been busting at the seems to tell everyone how good it is, but had to keep quiet. You have no idea how hard that was!
And the inflight compass calibration works a treat too. Even "upside down" for those in the southern world. It beats the heck out of doing it the hard way.
And the GAMI spread units are correct now too!
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 01-21-2015, 09:06 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
very nice update dynon... auto trim?..dang it, I may have to switch my manual trim to electric now.
Ryan Allen, CFI
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 98%, Working on Finishing Kit, AEIO-540 on the stand
Acro Sport 2 on deck.
Old 01-21-2015, 09:11 PM
Jesse's Avatar
Jesse Jesse is offline
Is this the first auto roll trim on the market? Very nice!
Jesse Saint
Old 01-22-2015, 08:49 AM
N427EF N427EF is offline
Default Excellent!
Excellent addition, The traditional compass rose on most airports are simply to small without enough room to maneuver around and line up with the cardinal headings.
Ernst Freitag
RV-8 finished (sold)
RV-10 IO-540 8.5:1
Running on 91 Octane E10 mogas since 2011
Old 01-22-2015, 08:56 AM
dave4754's Avatar
dave4754 dave4754 is offline
Default Forefliht anyone
I have a Dynon servo in my wing as i head to a full Dynon package soon. However a friend showed me his Foreflight and now i wonder what the glass panel in the dash really does for me.
Any comments
Nice work though Dynon, still headed there but .... money money money.
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 01-22-2015, 09:02 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Nope. Other vendors have Pitch, Roll, and Yaw auto trim already.
That said, great update!
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 01-22-2015, 09:09 AM
SteinAir SteinAir is offline
Nope...Garmin introduced that about a year ago - so this means that both of the most popular EFIS vendors now have it! That said, we find most folks end up not using it quite as much in comparison to the auto pitch trim (which folks really like a lot). Of course TruTrak gets the honor of having introduced that to sport aviation at a reasonable price a decade or so ago (same with an affordable Yaw Damper).
It can be hard to keep up with the maddening pace of offerings in avionics - so much neat functionality that sometimes it's hard to keep track of, even if you deal with all of them!
Stein
Old 01-22-2015, 09:42 AM
N941WR's Avatar
N941WR N941WR is offline
Any comments
In two years your friend's iPad will need replacing, due to either software or hardware obsolescence.
That said, Foreflight has put together a nice package but with the SkyView, I see no need for it. Just my $.02.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-22-2015, 09:46 AM
Brantel's Avatar
Brantel Brantel is offline
Any comments
Ever tried to use an Ipad in a bubble canopy RV outside in the daytime?
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
