Old 04-21-2019, 07:36 PM
Walt's Avatar
Walt Walt is offline
Originally Posted by RV8JD View Post
I should also mention that on the SkyView Touch if you're on the ground and there is no current altimeter setting, pushing the setting knob (joystick) to the left or right for two seconds when the BARO setting field is selected, adjusts the altimeter based on the current GPS altitude. After the BARO setting is synchronized a GPSALT message will appear in the altimeter setting box on the PFD, before showing the updated BARO setting.
For the G3X
BAROMETRIC PRESSURE
The barometric pressure setting is displayed below the Altimeter in inches of mercury
(in Hg) or hectopascals (hPa) when metric units are selected.
Selecting the altimeter barometric pressure setting:
Turn the Knob associated with the PFD to set the barometric pressure.
Or:
1) Touch the Barometric Pressure on the PFD.
2) Touch the Set For Field button if aircraft is on the ground.
Or:
3) Touch the Set To Standard button if aircraft is in the air.
Or:
4) Enter the desired pressure using the keypad and touch Enter.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-01-2019, 05:31 PM
Draker's Avatar
Draker Draker is offline
Here?s a feature suggestion: Any chance of G3X getting Bluetooth A2DP music input in a remote mount COMM/intercom? Looks like the panel mount GTR 200 has a ?B? option, but the remote mount GTR 20 has only wired stereo music input. Understood you could roll your own with an aftermarket BT adapter but it seems like a strange omission from the product line.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2019
RV-7A (N12VD): Empennage and wing kits complete minus fiberglass, fuselage and wiring complete. Canopy complete minus fiberglass. Waiting for the engine to come!
Old 05-02-2019, 12:51 PM
Ian Coates Ian Coates is offline
Default Certifying the GPS 20A
If the GPS20A was certificated as an IFR navigator then the G3X touch could have LPV approaches integrated without the need for an external navigator. It is at present a WAAS GPS that is accurate enough for ADSB.
That would be a great addition to the integrated G3X touch system.
VAF Donation 2020
RV7 Built and Flying
Old 06-05-2019, 08:00 AM
Bavafa Bavafa is offline
Default Flap/Trim settings
Wouldn?t be nice to be able to configure trim in relation to the flap setting. Garmin G3X with the combination of a GAD 27 already has the ability to set the flap at preset angle as well as control the trim. Why not have it so when we set the flap, it will automatically adjust the trim based on configured settings?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 06-05-2019, 08:46 AM
supik supik is offline
Such a system would need to take care of your current speed as well -to maintain the airplane in trim.
Igor
RV-10 in progress
Build Log
Old 06-05-2019, 09:25 AM
Considering there is airspeed limit for deploying flaps, the speed range wouldn't be a too wide. Furthermore, these settings much like the AOA settings, need to be calibrated and set by the pilot in the air and would work more effectively with a side by side than a tandem.
FPS-plus is an example of such system that does this and it does it very nicely.
https://www.aircraftspruce.com/catalog/avpages/FPS.php
With Garmin, all required inputs and controls are already there, I would assume only programing to make it possible.
Mehrdad
Dues paid
Old 08-18-2019, 08:01 AM
Hello Team X,
Any chance we could get this feature with the next sw update?
Igor
It would be comfortable to operate the G3X USER TIMER (stopwatch) by a remote button eg from the joystick. A discrete input could serve this purpose.
1click -Start
1click -Pause
hold button -Reset
Oh I really like this one!!!
Matt
CFI / RV-10
Really good suggestion!!! That would make the timer a lot more convenient.
Mark Hansen
Indianapolis, IN
RV-7A N896PS
Flying
+1, excellent!
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2019 dues worth every penny
Originally Posted by g3xpert View Post
Thanks for the idea. We are always trying to improve our products. I will see if this is something we may be able to do in a future release.
Keep the ideas coming, we try to our best to integrate your ideas when we can.
Levi
Team X Project Manager
Igor
RV-10 in progress
Build Log
Old 08-26-2019, 07:29 AM
agent4573 agent4573 is offline
Came here looking for info on this exact operation. The Garmin reps at Oshkosh this year were explaining the auto-trim vs airpseed function the g3x now has. I was curious if this was 2d map (trim position vs airpspeed) or if there was a way to make it a 3d map (trim position vs airpspeed and flap setting). Even if they didn't want to implement a fully blended solution, having 3 or 4 discrete 2d auto-trim profiles based on flap settings would probably work (profile 1 flaps 0-15, profile 2 flaps 16-30, etc)
Is there a way to make the Garmin system and the FPS-plus play nice together? Can the Garmin use an external input to disable it's trim controller? If I tapped into the output of the FPS trim controller and used it as an input into the Garmin system, could you program the Garmin to give up control once it sensed the FPS box was attempting to change the trim condition?
Old 11-05-2019, 08:26 AM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Default Friends list
Now that more and more people are getting ADSB out I find that my traffic advisory is driving me nuts. I almost always fly with a wingman or two and it used to be that I would only get traffic alerts from my wing man if we were more than about a half mile apart. We typically fly much closer than that and now that my normal flying partners have ADSB out I get constant traffic alerts. I don't want to turn the alerts off but if its constantly alerting it becomes useless. It would be nice to have the ability to either create a "friends" list of aircraft that would not alert or at least have the ability to acknowledge an aircraft only once per flight.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - FWF
www.DarinAnderson.com
2020 donation sent!
Old 11-05-2019, 09:23 AM
I don't know if there is a feature to acknowledge an alert and stop it from blinking all the time. If not, it would be nice to be able to acknowledge it and stop it.
Mehrdad
Dues paid
