04-27-2018, 05:22 PM
Originally Posted by Kwright
I’d like to be able to set Baro Minimums without leaving the Approach chart on a single GDU touch system.
Kent, I would suggest a G5 as a nice upgrade to your single GDU system. Not only does it give you a backup EFIS but it also talks via the CAN bus to your GDU allowing you to use the single knob on the G5 to adjust the baro setting. :-)
EDIT: Never mind... you said minimums, not baro settings.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - FWF
www.DarinAnderson.com
2020 donation sent!
04-30-2018, 09:48 AM
Originally Posted by Spirko
I have the same engine, it would be great if the G3X Touch could also read engine faults instead of my having to wire up the diagnostic software on a computer after I land.
Dynon has added the display of Faults via a recent SkyView software update. A Rotax 912iS is in my near future, as is a Garmin G3Xtouch. I would love to see the addition of Faults display added.
Michael
04-30-2018, 09:54 AM
Hello Michael - Not to worry, if you have a Rotax 912iS FADEC engine you can see detailed FADEC status and fault information simply by accessing config mode on your G3X Touch system.
- Matt
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
04-30-2018, 12:32 PM
Matt, that is awesome.
- Matt
04-30-2018, 03:13 PM
Checklists as an optional page on the main display screen.
Having to go back to them on the main screen isn't terrible, but it keeps losing my spot.
Matt
CFI / RV-10
04-30-2018, 04:20 PM
Multiple VNAV waypoints
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
04-30-2018, 05:34 PM
+1 on improved vertical flight planning/nav
05-06-2018, 01:48 AM
Discrete Input (momentary switch - ACKNOWLEDGE BUTTON) to cancel MASTER WARNING and MASTER CAUTION LIGHTS. E.g. if one of the MASTER WARN or MASTER CAUT indicators depressed, it would send the signal to GAD27 or GEA24 and acknowledge the warning or caution msg without touching the screen.
Igor
RV-10 in progress
Build Log
05-06-2018, 11:07 PM
Feature request: GMA 245(R) discrete input for pause/resume of Bluetooth audio source. (Possibly use the existing PLAY KEY discrete input for this, either when Bluetooth audio is playing or as a configurable option in lieu of the current functionality.)
05-07-2018, 02:24 AM
Weather via Internet
The ability to show weather via internet connection (hotspot wifi from cell phone) for us non ADSB europe flyers would be nothing short of amazing. Basically what the Area 660 can now do. Thanks
VAF dues paid for 2020
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
