Old 06-07-2017, 10:50 AM
newtech's Avatar
newtech newtech is offline
Default V number call outs
I have GDU 370's but would apply to all. Would like to have audio callouts of "Airspeed Active", "V1" and "V2" during the takeoff roll. The other V numbers applying to twins would probably be appreciated by those that can afford the 2x fuel bills.
My instrument instructor wants the "Airspeed Active" call out during the TO roll. This would seem to be a simple thing to add.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 06-13-2017, 06:34 AM
Timberwolf Timberwolf is offline
I love that G3x and foreflight talk, but without purchasing more equipment I still don't have adsb weather from my stratus on the g3x. Is there an easy way to port weather from the ipad (via the stratus) over to the g3x? This would at least give me a short term solution until I figure out what my 2020 solution will be. I got bit in the *** hard by the navworx issue on my other plane and wan't to wait this one out to see what comes out before jumping into another system.
Old 06-13-2017, 12:25 PM
bkthomps bkthomps is offline
i can't fathom why you would want your panel to be dependent on your iPad and a 3rd party device that is loose in your cockpit, why not just get a GDL39-R ? your iPad could use the info from it, and you could sell your stratus...
Old 06-13-2017, 04:00 PM
Sure, can't argue here. Preferred is the G3x would just use the stratus. But stratus is WIFI and G3X is bluetooth. Getting a GDL39 would mean no attitude info on foreflight. Is it needed as a backup to the backup G5? Absolutely not. Just trying to work with what I already have instead of doing this dickdance of selling off one thing to get another when in the end each item is only partially compatible. Until an adsb solution is in the books, just looking for a workaround with items I already have. That is unless there is a wifi dongle that will read directly off the stratus and inject it into the G3X...but I'm unaware of one.
Old 06-13-2017, 04:05 PM
i hate to break it to you, but experimental avionics may not be the market for you- that's what it's all about
why do you want your iPad to be a backup? the G5 is a perfectly adequate backup, and even good enough for the certified crowd
I think you may want to revisit your strategy, both the stratus and apple products have had issues with power consumption and overheating, they are not purpose built for what you are attempting to achieve, but rather tout the capabilities as part of their offering....the G3X with a GDL39R gives you everything you want, a G5 added in compliments it for redundancy- the iPad is a "nice to have EFB" and the stratus is off to eBay at this point
I find it curious that the Van's crowd, with limited cockpit space, is so keen on filling it with dongles, power cords, and iPads- when I ran my RV4, I was all about doing more with less
just providing constructive feedback, hoping to give you a different perspective- not trying to be a jerk or anything- by the way, i haven't ran a newer version stratus, do they reboot quicker? the 1st gen ones took forever
Old 06-13-2017, 07:35 PM
Ha. I think you're missing the point here. Experimental is all about not being tied to one specific system. But I'll just leave it at that and move on.
Old 06-13-2017, 11:43 PM
rjtjrt rjtjrt is offline
Re Australian equivalent of "Sectionals" being available on G3X Touch.
Airservices Australia (Government Publisher) have just released free online charts for first time.
http://www.airservicesaustralia.com/...May-2017&ver=1
Will this now allow Garmin to make these available for G3X Touch?
Hope so.
Old 06-15-2017, 08:07 AM
jthocker's Avatar
jthocker jthocker is offline
Default No Taxiway labels on Safetaxi😂
Not sure if there ever were labels for taxiways when zooming in on Safetaxi chart, but I don't have them now. A friend asked me why his legacy G3X didn't have the labels. I said my touch does, but then I checked and it doesn't! I'm pretty sure I've seen the labels in the past. Map detail is set for highest.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 06-15-2017, 04:21 PM
KRviator's Avatar
KRviator KRviator is offline
Hope so.
Considering it was our bloody Gumby-ment that caused the US DAFIF to be withdrawn years ago, free charts is the least they can do!
Just don't try to use them on an old Ipad without redoing them as a Jpeg or something!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 09-06-2017, 09:36 AM
N733JJ N733JJ is offline
Default Ignition timing?
I am running with Electroair ignition. It has provisions for a timing readout (which I have on a small LCD screen). It would be nice for this to be in the G3X, good information when looking downloaded at engine trend data. Should be simple to do, it is nothing more than a volt meter.
Scott A. Jordan
80331
N733JJ
