Old 01-20-2015, 05:55 AM
pa38112 pa38112 is offline
Default How Straighten Prop ?
I have an old FP metal prop that I want to strip down and polish to hang on my wall. The tips are bent from a ground-strike.
Any suggestions on the best way to straighten these? I have had problems straightening aluminum in the past. If I heat it I often melt a spot before I get the piece red (and this might leave a discoloration that I can't polish out). If I don't heat sometimes it cracks. Looking for some experienced help.
I am going to cut the very tips off to remove some deep gouges, but I didn't want to cut a lot off each end.
Thanks in advance - the knowledge base here is amazing!
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 01-20-2015, 06:01 AM
mv031161's Avatar
mv031161 mv031161 is offline
Default Prop
If you do straighten the prop, i would like to ask you to stamp it permanently somewhere in the hub section with the words " Scrap" or "unairworhty" Personally, a bent prop hung to a wall adds more character and the story grows each time with it! Check aC 43-13. Chapter 12 Section 3 talks about standard repair procedures
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 01-20-2015, 06:26 AM
Default Leave it bent
I've seen a polished (or chromed) bent prop blade as an art. Looks great!
Old 01-20-2015, 07:12 AM
Good Idea - I'll stamp it
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 01-20-2015, 07:13 AM
Vern's Avatar
Vern Vern is offline
Default Bent prop
I've heard guys say they put a plank over it and drove their truck over the planks to straighten bent props.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 01-20-2015, 07:58 AM
airguy's Avatar
airguy airguy is offline
I would leave it bent - it's an automatic conversation starter.
Old 01-20-2015, 08:02 AM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by pa38112 View Post
... If I heat it I often melt a spot before I get the piece red (and this might leave a discoloration that I can't polish out). ...
Aluminum doesn't turn color when heated, which is a challenge.
You could always cut it down and make both sides even again, assuming it is just the tips that are curled.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-20-2015, 08:33 AM
I did not bend this prop, and don't know who did - so not much of a conversation to be had there. - Also, it is not a pretty bend like many I have seen, and is asymmetrical from one end to the other.
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 01-20-2015, 10:13 AM
Michael White's Avatar
Then do what any pilot worth his salt would do.....make one up!
Moose
VAF #136
Old 01-20-2015, 10:17 AM
longranger's Avatar
The standard in EAA Chapter 1000 is 10% truth and you're good to go!
RV-7 TU 904KM (reserved)
Construction Log
