Old 10-29-2006, 07:20 PM
rickmellor rickmellor is offline
Default Dimpled flap hinge OK?
Related to this thread, but slightly different focus...
I've riveted on my flap hinges but afterwards I started to question my approach. I dimpled all three laters: skin, brace and hinge. In retrospect I would have preferred to have dimpled the skin, CS the brace and left the hinge alone.
What do you guys think? Should I tear it all apart and do it over or will it hold the way I have it? I'll call Van's in the morning but would like to get you guys' take on it as well.
-Rick
RV7A (aborted in 2007 )
Brooklyn, NY
Old 10-29-2006, 07:27 PM
Radomir's Avatar
Radomir Radomir is offline
Van's is OK with dimpling the hinge... that's what they told me when I called them one time..
Radomir
RV-7A sold
Old 10-29-2006, 07:31 PM
13brv3's Avatar
13brv3 13brv3 is offline
-Rick
Hi Rick,
I think the way you did it is absolutely fine, mostly because I just did mine that way a week or so ago. Forget about it, and move on
Rusty (flying in 2-3 weeks)
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 10-29-2006, 10:18 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Yes... but...
Since the hinge is a softer material, I would ensure that the shop heads are made towards the larger end of the tolerance....
Make them all at or above the 1.5D width dimension..... there are a lot of flight loads on this hinge line at max. flap deployment speed.....
Since you dimpled after drilling, the "top" of the dimple does have an angle, and you want to ensure that this angled portion is fully covered and that the shop head bears on full thickness material.
gil in Tucson ...
Did you manage to dimple the hinge and not turn it into a pretzel??....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-29-2006, 11:10 PM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default Is it straight?
I thought I read somewhere not to dimple the hinge because it will distort? I'm interested in this because I'm in a position where the flap brace is already installed though the wing skin/flap brace/ flap hinge has yet to be fitted. If I can dimple everything it sure will make life easy...
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 10-30-2006, 01:14 AM
I was concerned with the shop head size so I used .5 size over the rivet length callout (4.5's I think). I was careful with the pneumatic squeezer and managed to get them to set true.
The hinge did curle over when I dimpled it. It was uniform in the way it bent and when I straightened it back out the holes were still in alignment so it didn't seem to be a problem. The bending wasn't enough to make me concerned about fatigue.
I'll check all the shop heads again to make sure the dimple edges are properly covered.
Thanks guys.
Brooklyn, NY
Old 10-30-2006, 05:30 AM
RV6_flyer's Avatar
You are correct. You can dimple them but when you do, it distorts the hinge and it will be very difficult if not impossible to get the hinge pin in the assembly for the finished airplane. I was just looking at an RV-8 on Friday where the builder was having a very difficult time getting the hinge pin in the flap assembly on the airplane.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-30-2006, 06:35 AM
13brv3's Avatar
I know that Van's prefers that you countersink, rather than dimple the hinge material, but removing much of the "soft" material makes less sense to me than dimpling it.
As a test, before doing it on a real part, I took a section of scrap hinge material, and dimpled a bunch of holes. Since this didn't seem to deform the hinge, I started dimpling all my hinges. So far, no problems.
BTW, there are a number of factors that can cause pins to be hard to install. Squishing one of the eyes with your squeezer can sure do it
Also, when you force the prepunched holes of the flap hinge to line up to the pre-punched holes on the bottom skin, the result can easily be a skin that isn't perfectly straight along the hinge line. The soft hinge will be forced to conform to this, regardless of what shape it was in originally, and the pin will be tight when assembling the flap. This doesn't seem to cause any operational problems though, and you don't have to worry about the pin working it's way out
Rusty
A&P - 2018
Old 10-30-2006, 07:58 AM
Brantel's Avatar
Brantel Brantel is offline
Default Countersink the middle layer
Vans prefers that you countersink the middle layer not the hinge. Just like on the elevator trim tab hinge.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-30-2006, 08:39 AM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default Counter sink the middle layer
And just like on the flap itself.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
