Old 01-18-2015, 08:57 PM
moll780 moll780 is offline
Default carb heat muff and connector
Is there a better system than the Vans OEM carb heat muff?
I need to replace the scat tubing and the tube I bought is too stiff and presses down significantly on the airbox.
Im just wondering what other people are doing;
1. some kind of updated system that doesnt utilize scat tube
2. scat tube thats more flexible and pliable??
anwyay.. thanks in advance!
vans rv9A, o-320.
http://www.vansaircraft.com/cgi-bin/...=carbheat-muff
EDIT:
ok searching the site I found some threads and good options.
robbins and wicks muffs.
so ignore..
--2008 RV-9A
Austin TX
Old 01-18-2015, 09:11 PM
krw5927 krw5927 is offline
The muff at www.robbinswings.com is a horizontal design and captures more heat from the crossover exhaust. It will also let you use a longer piece of scat tubing which should eliminate the problem youre having.
Kurt W.
RV9A
FLYING!!!
Old 01-18-2015, 09:12 PM
these look great!
im fixin to call them in the morning.
thanks
--2008 RV-9A
Austin TX
Old 01-19-2015, 04:34 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default +1 for the Robbins muff...
I purchased one from Vetterman's with my new exhaust and it fit very nicely. I installed it on the front crossover tube.
I use the Van's one for my cabin heat.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
