Old 01-18-2015, 10:21 AM
ShortSnorter ShortSnorter is offline
Default Great start to a bad morning...
I finished work yesterday feeling somewhat accomplished after riveting the trailing edge of the rudder successfully after I had been putting off the task for nearly a week.
I walked into the "airplane factory" this morning with two seemingly simple tasks: 1) Roll the leading edges of the rudder and 2) Pop rivet the edges together.
I got an early start this morning and drilled a few holes in my bench and installed three u bolts to hold the 3/4" conduit I planned on using to roll the skin.
The first skin rolled perfectly as planned, so I moved on to the next skin. Low and behold it rolled just as easy and I was making good time! As I starting untaping the skin from the conduit my heart stopped when I got to the top of the rudder and saw this:
I apparently I rolled the conduit too far and the u bolt was driven in to the side of the spar. I literally sat and stared breathless and speechless for at least a minute, not believing what i was seeing. Adding salt the the wound the rolled edges went together absolutely perfectly!!
I know that I'll probably have to redo the rudder but I figured I'd share and make a deposit to the "be careful of this" repository.
Maybe I'm just being optimistic, but the bend did not seem to move/affect the rivet orientation. In other words, the depth of the dent in the spar flange doesn't seem to be deep enough to affect the rivet.
Old 01-18-2015, 10:54 AM
Kahuna's Avatar
Kahuna Kahuna is offline
I would not be building a new rudder. Seaming pliers slowly and gently to prevent cracking, will get it close to correct, then an impact flush set and a bucking bar, or tap hammer and bucking bar, will finish the job nicely. Then a little filler before paint, and your good to go.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 01-18-2015, 10:59 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Pretty sure Kahuna has it nailed, but you might want to run it by the factory just for your own peace of mind.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-18-2015, 11:00 AM
wirejock's Avatar
wirejock wirejock is offline
Default Rudder
Before you loose hope, send an e-mail to the Mother Ship. You never know.
You might consider J-bolts instead of U-bolts. On mine, I ground the end of the J-bolt to a smooth round end so it rides up and over. I still watched them to make sure but it also allows the bend to go farther till the J-bolt touched the spar web.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 01-18-2015, 12:21 PM
Thanks for the input, an email has been delivered to Van's. Sometimes the smallest oversight can cause major heartache!
Old 01-18-2015, 12:54 PM
bddalm's Avatar
bddalm bddalm is offline
I agree with Kahuna. Remove the fastener, straighten with seaming plier and you can route out a little of the edge to make a smooth transition. Just maintain edge distance on the fastener.
Brian Davis
www.adventuresinaviation.org
RV7A
KFFC-Peachtree City, GA
Old 01-18-2015, 06:11 PM
KJBSouth's Avatar
KJBSouth KJBSouth is offline
Others have encountering the same problem. You are not alone. I just finished rolling the elevators using the homemade J-bolt procedure mentioned elsewhere on the Forum. I have found it very useful to search the forums for part numbers on each step of the build. It's saved my tail several times.
Karl Bambas
1954 1st solo
1964 Mooney Statesman, 1979 C-172, 1948 Globe Swift (all sold)
RV-7 "Dream Weaver" N50KB
Empennage arrived 10/14
QB Wings & Fuselage arrived 06/15
Finish & FF kits arrived 11/15
Dual screen Garmin G3X instruments and harness delivered by Stein 01/16
First flight June 13th 2018
2021 Dues Paid
Builders Log
Family Blog
Old 01-18-2015, 06:20 PM
DragonflyAero DragonflyAero is offline
A pneumatic squeezer with flush sets in both sides might also work to flatten this out. I have used this on a number of oops occasions. Remove the rivet, flatten, redimple and then rivet. You will have to look hard to find any trace!!!!
Bill Vinson
RV-7 Standard Build
http://www.mykitlog.com/users/index....r&project=2226
Old 01-18-2015, 06:24 PM
sblack sblack is offline
I would use a plastic mallet or deadblow hammer and a dolly. Seamimg pliers will leave marks and a metal hammer will stretch the metal. The dolly could be a pc of hardwood sanded to the right radius and it could have a recess for the existing rivet. Whatever you do do it slowly and patiently. Sneak up on it, don't try to repair it in 3 blows. A half hr of gentle tapping and checking is much safer.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 01-18-2015, 08:58 PM
ERushing's Avatar
ERushing ERushing is offline
Ouch. I used the same method and realized just before I was about to do what you did. I got lucky.
I wrestled with that leading edge for probably 8 hours trying to get it how I wanted it (perfect.) That's the one thing in the build so far that I'm really not happy about. It'll fly. It'll be safe but it didn't turn out how I wanted it!
Good luck!
Eric Rushing
RV-10
90% done, 90% to go.
Looks like an airplane!
Molalla, OR
