Old 01-18-2015, 07:31 PM
Bart Bart is offline
Larry, yes confirmed plus checked continuity. And agree it's terribly difficult to do this from the back.
I'm thinking either its a setting or the 1200 dollar ES upgrade might need a do-over.
Definitely wasted a whole weekend on this challenge.
Old 01-19-2015, 09:12 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Bart
Do you have a return ground? The GPS must be receiving your position and the transmitter must be transmitting. Is your encoder talking to the 330? Is the squat switch set to no?
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 01-22-2015, 11:20 AM
To finish this issue off I'll pass all by the final corrective action to resolve our "no adsb" annunciation. Turns our wiring was fine. Our settings were right. The 430W system software was upgraded to 5.1 which should have done the trick. The problem arose when the GPS software (other card) went out of date. So an upgrade to 5.0 on the GPS card and the message disappeared. So lesson learned make sure both cards are up to date. Note: the first garmin tech said it (GPS software) wasn't the problem. A second call to Garmin (new tech) said it was indeed the problem.
Old 01-22-2015, 11:54 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Bart, glad you got the issue straightened out, and thanks for reporting back about the solution.
I moved this thread to Glass Cockpit, as it applies to more than just the 10 folks.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-22-2018, 08:46 PM
cojaken cojaken is offline
I?m having the same issue. Does the above reference to ?an upgrade to 5.0 on the GPS card? mean an update of the terrain database please?
Old 10-22-2018, 11:23 PM
BobTurner BobTurner is online now
Not the terrain database. The gps software.
Old 10-27-2018, 08:38 PM
Thank you Bob. That explains it and also seems to have been the solution!
Old 12-02-2018, 08:35 AM
Lux Wrangler Lux Wrangler is offline
Default NO ADSB fault
I had my Garmin GTX 330 converted to es and wired it to a RS-232 port on my GNS 430w . I have tried several ways to set ADS-B out+ on the 430 and remote on the 330, I hope correctly. Integrity is set to 1E-7. ADS-B TX and EHS are enabled. Still I see NO ADSB fault on the 330.
Jim Peck
San Francisco Bay Area
RV-7
Old 12-02-2018, 11:10 AM
Are you receiving gps data on the 430w. Does the 430W have the latest software release. If you are seeing the adsb+ option on the serial output, then you have the latest software... Do you have the proper data speed selected for both ports?
Bill Peyton
RV-10 - 1125 hrs
N37CP
Old 12-02-2018, 03:52 PM
Default NO ADSB
Bill Peyton
Yes, I have the latest software (I should have mentioned that). I saw in the installation manual that the 330 is capable of a second speed, but I haven't found where to check/set that parameter. The 430 shows the normal good GPS data.
Jim Peck
RV-7
