Old 01-16-2015, 12:57 PM
kjlpdx kjlpdx is offline
Default scuffed master cylinder
my R Cleveland master brake cylinder was scuffed, the piston especially, so it was not working very well. I have replaced it with a Matco. in talking with Rian at Vans he mentioned that this isn't an uncommon problem. he noted that on his BMW they tell you to only bleed brakes using a vacuum at the wheel and not push the fluid up the line. I have pushed fluid up the line for years. my plane has always pulled left because I believe the nose gear wasn't drilled correctly to begin with. consequentially I have worked on the right brake many times over the years and replaced the rotor even. Rian thinks, and after disassembly and inspection I agree with him, that pushing the brake fluid up the line pumps any burnt fluid and gunk up into the master and reserve tank. so I bought a vacuum pump, HF $23, and sucked the fluid down this time. the pump has a tank that collects what is pulled down. it was noticeably darker than the new fluid. there also were black specks in the cylinder when I took it apart. we'll see how the next 1400 hrs goes!
RV-6A 1500+hrs since 1997
O-320 D2J, FP, slo-bld
49 states, Bahamas, Canada
2014 - PAID
Old 01-16-2015, 01:17 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Smile Thanks
Very helpful post. Thank you!
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 01-16-2015, 02:27 PM
Ralph Inkster Ralph Inkster is offline
Default scuffing
Dirty fluid probably doesn't help matters, but my theory for scuffing pistons is the way the m/cyl is mounted. The offset bolt arrangement in my view causes a side loading of the rod (plunger) as foot pressure is applied and eventual scuffing results. Maybe how tight the mounting bolts are set is a contributing factor as well, looser or floppier the m/cyl is the more likely to scuff??
I've replaced a few on various RVs & accept that these are eventual maintenance items.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 01-16-2015, 05:09 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Fluid should be changed periodically. Here Dick says this at minute 3:20
http://www.eaavideo.org/video.aspx?v=2520200703001
http://bcove.me/2pw4q9fe
