01-15-2015, 12:32 PM
Which mag to ditch for single EI
It appears to me that the right mag is usually replaced when a single EI is installed usually to retain the impulse coupled mag for starting purposes.
I have heard someone suggest that the left mag is the most mechanically complex and should be the 1st to go. Starting is not an issue due to the fact that if you have enough juice to spin the starter then you have more than enough to fire the EI. Even if you can't turn the engine over there is a decent chance there's still enough voltage to fire the plugs with a hand prop.
Curious to hear from those that have done this and their thoughts on it.
Kelley Kokemiller
9A sb N94KK 400hrs. and counting
Barrett O-320
Catto 3-blade
Panther tail complete
01-15-2015, 03:07 PM
I replaced both ignitions with PMags so this does not answer your question, but starting when the battery has gone flat due to me leaving the master on has not been an issue, hand propping usually has the engine running on the second pull through.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
01-15-2015, 03:15 PM
I replace the impulse coupled mag first. A failed impulse coupling could drop it's damaged self into the gears of the accessory case, causing the engine to fail.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
01-15-2015, 04:16 PM
Normally you keep the impulse coupler to facilitate starting if the EI fails or battery is dead and then that differs between Lightspeed and P-Mag. Of course that might then beg the question who cares if you start and don't intend to fly on one ignition if it wasn't just the battery.
But yes, it's imperative to inspect the coupler along with the mag at regular intervals. Mine was going south at 500 hours on the mag and yes, it's failure will make a big mess!
01-15-2015, 09:02 PM
Here's another vote for impulse mag on the left and EI replacing the right mag, has worked great for me for 670+ hours.
Reggie Smith ______
RV-8 Wish List/RV-4 Experience
Glasair 1-RG Flying
Vision Microsystems EPI800 & VM1000 support:
http://vmsupport.weebly.com/
01-15-2015, 09:23 PM
You'll be able to hand prop it even with a dead battery.
Same set up for me and I always start on both, starts like a car.
Concerns about the complexity of the impulse coupling are valid but hundreds of thousands of airplanes are flying with them and aren't given it a second thought.
Keeping the non impulse coupled mag will force you to start on the EI only or else you'll loose teeth on the ring gear.
needless to say you won't be going anywhere with a low or dead battery.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
01-15-2015, 09:54 PM
Same here. I had toggle switches and never could start the engine on the Lightspeed alone. It came online once started with the impulse mag. Had about the same amount of hours as above when sold.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
01-16-2015, 12:11 AM
LIghtspeed on left, slick mag on right
My engine starts on the Lightspeed just great. Part of my decision was easier because my engine didn't come with an impulse coupling mag. Instead it came with a dual point mag on the left, made to use with a "shower of sparks" ignition box.
I didn't want to bother with all that, so I ditched it.
If I had an impulse-coupled mag, it would have been a harder decision, not sure what I would have done.
I've found with a light composite prop, I don't think I could hand prop it anyway, just not enough inertia to get it to swing through. Maybe with an impulse coupled mag it would fire anyway?
Excuse the thread drift, but another issue with hand propping for me is with bendix FI, on a warm engine, it takes a lot of cranking with WOT and full lean to get it unflooded. So I doubt I could ever hand prop a warm Lycoming with FI. Not an issue with a cold engine, it usually fires on the second blade.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
01-16-2015, 05:07 AM
Thanks for the input so far everyone.
I have spoken to Brad at Emag and he said he prefers to replace the left mag with pmag but I have decided not to go with his system.
Klaus said that he would pull the left mag and leave the right and leave all the starting up to the plasma as well.
Personally don't know anyone that runs this way but it does have merit. Just want to make sure there isn't surprises I haven't thought of.
Kelley Kokemiller
Barrett O-320
Catto 3-blade
01-16-2015, 07:20 AM
Given that direction you'll have two potential issues:
1. how will you start with a dead battery?
2. how will you start with a bad EI?
I've had both, #2 several times.
Good luck.
