Old 01-15-2015, 11:05 AM
Relentless's Avatar
Relentless Relentless is offline
Default Unleaded Fuel?part of design of AX50 cylinder design?
This question comes up during most calls and I know the concept is not mainstream yet so here is an attempt to start conversation about our new ACE AX50 cylinders and the unleaded fuel advantage of our components. While they will run leaded fuel just fine, we would actually prefer our customers ran unleaded fuel exclusively.
Cleaner engine, better economy, and many synthetic oil options are some real reasons for looking at the R Series components.
How is it possible to use unleaded, lower octane fuel with R Series engines developed by ACE Performance and now available from Titan Engines?
First, we need to understand a little about fuel octane ratings, there are a lot
of books on the subject but basically the higher the octane rating the more resilient to the fuel is to knock (pre-ignition).
Commercial fuel blends have a scale that runs from 0~100 and these
numbers are based on two fundamental hydrocarbons, one knock resilient
(100)the other exceedingly susceptible to knock (0), this is basically
how the two ends of the spectrum are decided.
Knock rating of a fuel is determined by running a test engine under
strictly controlled conditions. The octane number achieved depends on
the type of controlled testing. Currently there are two fundamental
methods, one is RON and the other is MON. This controlled testing though
does not really correlate with real world operating conditions. It has
been found to be somewhere in between the two testing methods and
therefore and average of the two is taken RON+MON/2
Contrary to popular belief, putting in 100 octane fuel will not give you
an instantaneous 20hp gain. It will however, as an example, *allow you to
achieve the higher hp figure by using a higher compression piston.
Secondly and more importantly is the design of the combustion chamber
and the effects it will have on an octane number.
As we increase the compression ratio, the cylinder pressure and
temperature will rise to such a level that eventually the end gas will
spontaneously burn. This is the reason why a higher octane fuel is used
to suppress this spontaneous burn (detonation) with increasing
compression ratio.
Here is a rough Minimum octane necessary with specific compression ratios for standard Lycoming engines:
Octane/Compression
50/5.0
70/6.8
80/8.0
90/8.7
100/9.0+
The detonation itself, which is a function of the end gas spontaneously
burning, will have shock-waves moving through the cylinder charge at
velocities in the region of 1200m/s. These waves reflect against the
cylinder and combustion chamber wall, these are then set into a state of
vibration which you hear as a ping or a knocking sound.
There are many methods, but the following or a combination will
considerably reduce the onset of knock.
1.) Increase the charge turbulence and flame travel distance, this reduces the
mixture end temperature.
2.) Reduce the flame path time this allows for a reduction in ignition
timing event.(If peak pressure occurs at TDC then higher pressures and
temperatures will occur)
3.) Ensure design of the mechanical components are not conducive to knock.
4.)Raise the octane number.
The AX50 cylinder and pistons are designed as an optimized package that
takes careful consideration into account of the above.
The combustion chamber is radical departure from the standard 360 type
cylinder head. It has a recessed chamber with squish bands (the charge
is squeezed radially inwards towards the center of the combustion
chamber),this promote higher than average flame speed along with
induced swirl by this means we are able to mix vigorously the fuel mixture before
combustion which will assist in a faster combustion pressure rise,
allowing for a reduction in ignition timing and at the same time
allowing for a considerably leaner mixture.
(image of the surface of a AX50 piston burn pattern)
The spark plug location on the AX50, whilst similar from the outside is
again very different on the inside, the plugs are much closer together
allowing a substantial reduction in timing due to the increase in burn
speed.
(AX50 Cylinder showing close location of spark holes as well as bathtub shape of combustion chamber and squish band)
The AX50 piston, has a shape that mimics the cylinder combustion shape
and this shape forces the charge into the center. The top land on the
AX50 piston is greatly reduced and this minimizes the crevice volume.
The crevice volume is the area around the top of the piston down to the
top of the top ring, this fills with unburnt fuel and if
temperatures increase too much, the unburnt fuel spontaneously ignites.
(AX50 piston shape and small upper land)
So, why can we run lower octane unleaded fuel?
www.ACE-Performance.com totally redesigned the cylinder and piston assembly
incorporating known, scientifically proven design details into our
product that the standard 360 and (soon 320) type engines simply do not have.
I am RELENTLESS...
R Series Engine Information
Rv8 ACE-360r
Nemesis NXT (building ACE-750r)
Old 01-15-2015, 11:42 AM
Robert Anglin Robert Anglin is offline
Default Thanks.
We have seen this type of configuration in Hi-prow engines in other than aircraft engine build-ups over the years and understand the application. Just a quick question if I may. Has Jimmy or you guys gotten a "Rough minimum octane necessary with specific compression ratios" charted out of any dianomometer runs, with respect to these AX-50 heads and pistons? It would be nice to see the two charted out together. I agree the day of no-lead fuel in our little toys is closing in on us. I for one have expected it to have already have past. Thanks if you can. Yours as always. R.E.A. III #80888
Old 01-15-2015, 12:09 PM
Bevan Bevan is offline
Originally Posted by Relentless View Post
Octane/Compression
50/5.0
70/6.8
80/8.0
90/8.7
100/9.0+:
Does the above chart refer to ron, mon or (ron+mon)/2 method of octane determination?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 01-15-2015, 01:08 PM
DanH's Avatar
DanH DanH is online now
Very good explanation Kevin. And my compliments to Andy; he did a nice job with those chambers.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-19-2015, 06:23 PM
AC Aero AC Aero is offline
Yes the table listed is based on the ron+mon/2 method. Please understand though, that there are always going to be slight differences in the real world due to the ron mon testing being carried out under controlled testing in a lab.
Old 02-06-2015, 07:02 AM
sonicapollo sonicapollo is offline
So obviously airport mogas is fine and most likely pump pure gas for those who can find it. My question is will the ax50, mainly the r409 engine, run on regular old 93 octane pump gas with 10% ethanol.
Old 02-06-2015, 07:44 AM
Relentless's Avatar
Yes, I am doing this right now in my R409 Rv8.
I am RELENTLESS...
Rv8 ACE-360r
Old 02-06-2015, 08:17 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Matthew, welcome to VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-06-2015, 12:43 PM
12vaitor 12vaitor is offline
The AX50 looks like a good candidate for Direct Injection and associated electronics to automatically run LOP in cruise. Chevy has a new 2016 Driect Injected engine with 12.5:1 compression running on 87 octane unleaded gas. It would be nice to get the HP assoicated with high compression aircraft engines but running on regular octane gas. Do you think this technology will be coming to aircraft engines anytime soon?
John Salak
Old 02-06-2015, 01:07 PM
Relentless's Avatar
John Salak
I am sure direct injection could happen today. I think Robert from EFii spoke about this and it is just a matter of price. I seem to remember him commenting it would not improve much more that his batch fire system does now. Maybe he will comment, he is the expert on this.
I am RELENTLESS...
Rv8 ACE-360r
