Old 10-29-2006, 09:09 AM
prkaye prkaye is offline
Default deburring holes in tight flanges
Now that you guys have solved my problem of how to dimple holes in between tight flanges (vice grip dimpler ground down a bit, works great!), how about de-burring in those spots? My deburring tool won't get into those tight spots...
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-29-2006, 09:21 AM
G-force's Avatar
G-force G-force is offline
Scotchbrite pad or small piece of sand paper. You just need to knock off the burr, not countersink it.
Mike Sumner
Castaic, Ca
Old 10-29-2006, 10:50 AM
szicree szicree is offline
You really need to get one of these in 1/8 and 3/32 sizes. I built 90% of my plane without, but now that I have them I wish I'd had em sooner. They are a little expensive, but a great tool.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 10-29-2006, 11:03 AM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Default One of what Steve?
One of what Steve? Burraways, by any chance?
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 10-29-2006, 12:32 PM
Oops! Yup, one of these:
http://www.cogsdill.com/pdf%20files/usdeb_burraway.pdf
Steve Zicree
Old 10-29-2006, 04:17 PM
C-GRVT C-GRVT is offline
You can also unscrew the deburring cutter from the tool, and slip on a tight fitting short piece of flexible hose over the threads of the cutter, and use that to spin the cutter - let's you get in some places easier.
Bill
Old 10-29-2006, 05:49 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Correct version
Steve... interesting reading, thanks for the link....
If you read Page 10 of the PDF file, it seems like the "standard" item they ship is not really the one we need for our RVS.
We need the light-duty spring and the zero degree rake blade for our aluminum sheet. Something to watch out for if you just go out and buy one surplus, or from a machine tool supply place....
It seems like the "standard" one they ship is for steel or SS.
gil in Tucson - this is one case for the "right tool for the job"
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-30-2006, 10:24 AM
borislav borislav is offline
Originally Posted by az_gila
SWe need the light-duty spring and the zero degree rake blade for our aluminum sheet. Something to watch out for if you just go out and buy one surplus, or from a machine tool supply place....
When I asked Cogsdill, they said the standard-duty spring is fine for our application. The actual tension on the spring can be adjusted via a set screw. Yes, we need the zero-degree, a.k.a neutral-rake blade.
A few more pieces of info:
- The burraway should be spun at about 1000 RPM, says Cogsdill.
- The 3/32" burraway is a little too loose for #40/#41 holes; the 2.5mm metric version fits much better.
- You can order directly from Cogsdill - 803-438-4000, ask for inside sales.
I love my burraways.
Regards,
Boris
Boris Deianov
-7 wings
Mountain View, CA
