  #21
Old 01-13-2015, 10:47 PM
mr.sun mr.sun is offline
Default Maintenance tail stand for tail draggers
I use an office chair with the back removed. Padded seat rests under the aft fuselage just forward of tailwhel stinger. Perfect height for tailwhel maintenance.
Greg RV-7 flyer
Donated Again
Old 01-14-2015, 09:16 AM
mv031161's Avatar
mv031161 mv031161 is offline
Originally Posted by kinger View Post
I can do tailwheel maintenance at the same time too.
[IMG][/IMG]
NICE!!!!!!!!!!!!!!!!!!!!!!!!!
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 01-15-2015, 02:53 AM
newt's Avatar
newt newt is offline
For tail wheel maintenance, I just rest the stinger on an upturned milk crate
- mark
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
Old 01-16-2015, 10:12 AM
ao.frog ao.frog is offline
Default Tailstand
I have made a tailstand from wood, and it was a fairly simple task:
I've made it so two of the aft bulkheads rest on the stand.
To lift the tail up and down, I use a Tailmate:
This makes servicing the tailwheel very easy:
Also; when I work inside the fuse (annual for example), it's easier for me when the fuse is level, so I use the tailstand on those occations too.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 01-16-2015, 12:38 PM
alpinelakespilot2000 alpinelakespilot2000 is online now
We seem to be combining apples and oranges here. We're talking about two things that serve different purposes.
As someone above mentioned, the tail lifter should be used just to lift the tail. It can be handy because lifting the tail up high with the rudder in the way can be tough. Good for minor maintenance, changing the oil if your sump drain would benefit, or when you need to level the fuselage for some reason.
If, on the other hand, you want to do work on the tailwheel itself or do anything where you might be climbing into the aircraft, then something more substantial should be used. It need not be anything complicated, however. Just throw a saw horse under the stinger or one of the aft bulkheads and be done with it.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
