Originally Posted by BloomerJohn
Can somebody provide vendors who make a 3" air scoop that would be mounted just inside the left cowling opening to direct more air volume into the 3" supply line going to the heat muff? The Aviat Husky uses a 2" one to provide greater volume of air across the heat muff. I need 3" to surface mountable one. Thanks in advance! John Nielsen (living with sub-zero OAT's in this midwest winter!)
John,
I think you will have difficulty getting much benefit from the approach you are considering. You would be trying to force more air through the 2" scat hose that flows warm air to the cabin inlet valve. A scoop may not be able to overcome the pressure that is already present in that 2" scat. I say this based on my experience with several different configurations and placements of naca vents with oil coolers and intercoolers on my RV7A airframe. I did have some success with a modified NACA with a helper scoop added to it, reaching out into the faster airstream to get some air. NACA vents can be a real challenge if using them in an attempt to flow air into an area that already has some positive pressure.
Adding a second heat muff and inlet for it might be an option. I know that this is an option for me with the new Vetterman "Trombone" system. I would think the normal cross over system might be able to accomadate a second heat muff, if you have room for a second cabin heat valve etc.
Another possibility to gain at least a perception of warmth is a 12 volt electric heater. I flew a Lake Amphibian for 3 years, and it came with a little 12 volt heater that would glow red and look like it was putting out some heat. I learned to just dress for the OATs I was going to be flying in to be comfortable
Randall in Sedona
Oh, I guess you could move down here as another option
