Old 01-07-2015, 07:44 PM
majuro15's Avatar
majuro15 majuro15 is offline
Default High Performance Oil Cooler Shroud
In one of my all night research binges, I stumbled across a fiberglass oil cooler shroud for the 10 / 540 that was supposed to smooth and increase air flow over the cooler. It had a fin inside the shroud and a round duct to attach the SCAT to. I thought I had bookmarked it but apparently sleepily forgot.
Anyone have any clue of what I'm thinking of and better yet, experience with such a addition?
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
Old 01-07-2015, 07:47 PM
Jesse's Avatar
Jesse Jesse is offline
In most cases, a stock cowl with stock baffles and oil cooler box runs just right. If in hot temperatures, a higher capacity oil cooler is just right. No need to reinvent it.
Jesse Saint
Old 01-07-2015, 08:26 PM
cjhammes's Avatar
cjhammes cjhammes is offline
Is this what you are looking for?
http://www.airflow-systems.com/oil-cooler-air-plenums/
I haven't used one, but they do look interesting.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 01-07-2015, 08:36 PM
N427EF N427EF is offline
Default Maybe this?
This is a 5" tapered into a 4" duct and works extremely well in California summers at 100 plus degrees.
I never see oil temps over 200F on even the hottest days and for the most part during the winter month I keep the butterfly valve closed all the way.
I added an extra 2" flange for additional air just because I heard of some 10s struggling with hot oil temps.
You may not need it just like Jesse pointed out but in case you do, this is what works for me.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 01-08-2015, 07:03 AM
DanH's Avatar
DanH DanH is offline
Build whatever you want:
http://www.vansairforce.com/communit...ad.php?t=44856
A turning vane (previous post and below) is easily added if you suspect separation at the small radius side of the turn.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-08-2015, 12:41 PM
JDanno JDanno is offline
I used the "45" listed at Airflow. Tight fit but works so well that even in the summer I would have to choke it down a little bit.
Old 01-08-2015, 06:11 PM
majuro15's Avatar
I've seen the Airflow kit. The one I'm thinking of was similar, but a little "smoother" shaped. They had a fin in the middle and the webpage even had some fluid dynamic screen shots of the internal air flow.
Not overly concerned about oil cooling without it, was just more curious and aggravated that I forgot to bookmark it!
www.N1017H.com
PC-12 Pilot
EAA #: 1106970
2020 VAF Dues Paid!
Old 01-09-2015, 06:15 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
The airflow site has those diagrams. They are in the "Oil Cooler" section. Here's a link.
http://www.airflow-systems.com/wp-co...stallation.pdf
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 01-09-2015, 08:20 AM
Greg Arehart's Avatar
Tim,
Should be able to find it if you look in your browser "history" pages.
Greg
Greg Arehart
N 7965A
Old 01-09-2015, 01:16 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I have had no issues with oil temps in my Rv10. I did make sure I sealed the heck out of the oil mount box on the firewall - every gap and seam was sealed. I also sealed between the oil cooler and the mount where there were gaps. I use the servo controlled butterfly valve to open and close the cooling source and in the summer I have never had a heat issue. In the winter, I can close down the air easily to control the temperature.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
