  #11
Old 01-07-2015, 04:41 PM
erich weaver's Avatar
Originally Posted by Low Pass View Post
Or an overvoltage annunciator. Second most critical to a low oil pressure annunciator. Looks like that battery cooked for a long time.
Overvoltage events, though rare, can happen almost instantaneuously. You would not be able to manually shut your alternator down in time to save your avionics in such cases. You need automated overvoltage protection to save the day.
Old 01-07-2015, 05:44 PM
SHIPCHIEF SHIPCHIEF is offline
I tried a cool little permanent magnet alternator from a John Deere garden tractor, but the high RPM caused by the Lycoming pulley size caused an over voltage condition before I ever flew it. I noticed the regulator driven idiot light flashing during Static RPM testing, and the volt meter just starting to break out of the 14.4 previous volts.
Now I have a DENSO Mini 2 ear alternator. It's a sweet little one wire unit with internal regulator. I'm sure these are very popular with the RV crowd, as they are light and put out a generous current. They are also very inexpensive.
What they don't have is overvoltage protection.
Lynn French (comments by 'Lectric Bob) went thru the bother to open a DENSO up, and add external regulation and posted the results online:
http://www.aeroelectric.com/articles...Conversion.pdf
I would be interested in retaining the internal regulation and simply adding the field shutdown circuit. Does anyone recall a DIY post on this? Or have anything to add?
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 01-07-2015, 06:26 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Didn't say over voltage devices weren't good. But an alarm (if noticed) would have allowed him to protect the battery because this event occurred over many minutes.
But further, what avionics would be harmed by 15, 20 volts? My Dynon info says it's good from 12-30 volts, King radio, xpdr - 12-24. Garmin G3X, 10-32 vdc. (These are the specs, didn't say I would try it! )
I did have an over voltage condition some 12, 13 yrs ago. I lost a couple of LED elements on my trim pos indicator (nothing else). No annunciator or protective devices. I spotted the volt meter at 17, 18 volts and shut off the alt field.
Old 01-07-2015, 06:50 PM
I don't consider myself an expert in such matters, but to my knowledge, over voltage events are not limited to the 15-30 volt range.
Erich
Old 01-08-2015, 06:14 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Perehelion Design
Originally Posted by DennisRhodes View Post
Does anyone know of a supplier for a "free Standing" 14 v system over voltage protection module aside from the built in models usually included with the Alt or external regulator?
I would recommend this one:
http://www.periheliondesign.com/lovm.htm
It has a trip level of 16.2 volts. It is not a "crowbar", which forces a circuit breaker pop or fuse blow, but a device which senses the overvoltage and then interrupts the field supply gracefully.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 01-08-2015, 06:25 AM
DanH's Avatar
DanH DanH is offline
Be aware the common Plane Power alternator has a crowbar built into its internal regulator.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-08-2015, 07:08 AM
John Tierney John Tierney is offline
Default B&C OV Protection
Will this do?
http://www.bandc.biz/over-voltageprotectionmodule.aspx
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 01-08-2015, 07:16 AM
Camillo Camillo is offline
Not to highjack the thread, but if you install a B&C regulator (which has an O/V protection) take care to cover it in a way so no water could enter in it. I experienced a recurrent electric system fail, included continuous alternator field braker trip which almost made me abort a travel in Greece, untill I discovered it was dued to water inside the regulator. Regulator is installed in the upper portion of the firewall (engine side) and of course is covered by the cowl. However, I suspect that when parked outside during rain, water enters between the cowl and the upper fuse skin and then in the regulator. See my RV9 site, FLIGHT! page for details.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 01-08-2015, 07:37 AM
Low Pass's Avatar
Very good to know! Might look that way at next replacement opportunity.
Old 01-08-2015, 07:59 AM
krw5927 krw5927 is offline
Camillo
Perhaps the B&C regulator manual has been updated since you purchased yours. It now contains this rather stern warning: "NOTE - take care to choose a mounting location that will protect the LR3C from heat, vibration, and water".
Additionally, mounting on the cabin side of the firewall is encouraged in the manual.
Kurt W.
RV9A
FLYING!!!
