01-01-2015, 01:36 PM
Walt,
Piper recommends 24 or 26 psi (would have to check my POH for which) for my Cherokee 180, so I never gave the RV-12 reassure a second thought. What was it that made you think that too low? I agree that in two months they'll be lower.
Rich
01-01-2015, 02:52 PM
Originally Posted by RFSchaller
Walt,
Rich
Well maybe just my experience, I can't think of a single flat I've seen/repaired that was caused by a puncture, its always some type of split in the tube which is "generally" caused by excessive flexing of the sidewall which can be attributed to low tire pressure. I have no objection to the manufacturers recommendation, but one must be diligent about maintaining specified pressures if you want to avoid problems (flats). If you get into that 15-20 range you are just begging for trouble.
On another note I wonder how many folks actually check their tire pressures every 30 days?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
01-01-2015, 04:49 PM
Why do they leak down so bad? My unfinished plane has never been out of the garage, and they lose air regularly, still have the stickers on them.
01-01-2015, 05:07 PM
been here awhile
Originally Posted by Walt
....If you get into that 15-20 range you are just begging for trouble......
With our little 5.00x5 tires 15-20lbs looks FLAT! You would have to be very inattentive to let them get that low. Looking at the tires is part of the pre-flight, and it's possible to get pretty good at sensing low pressure once we have learned the plane. I keep 26-35 lbs in the RV-6 and (knocking on wood....) haven't had a flat in 16 years. More than 35 on the RV-6's springy gear is more harsh than I can stand.
My experience with leak-stop tubes has been that air needs to be added about every two months to keep pressure within 2-3 lbs of target pressure.
Don, you are probably seeing leakage from the original, natural rubber kit tubes which are quite porous. The "leak-stop" tubes are made of some sort of synthetic rubber (like auto and motorsickle tubes) which maintains pressure much better. You will want those tubes once you start flying.
01-01-2015, 05:43 PM
In addition to the already-mentioned leak-stop tubes, fill with Nitrogen instead of compressed air. It is alleged that the Nitrogen won't leak as much as plain air.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
01-01-2015, 06:00 PM
Are you referring to the LeakGuard tubes found at Aircraft Spruce or something else?
Tom
01-01-2015, 06:10 PM
Leak guard, leak stop, also found a Desser Tire.
http://www.desser.com/products_airtubes.php
RV-6, RV-6A, T-6G
ATP, CFII, A&P
01-01-2015, 06:42 PM
Leak guard style tubes have been standard in RV finish kits for quite a few years now.
Scott McDaniels
Hubbard, Oregon
01-01-2015, 08:44 PM
been here awhile
Thanks, Scott, glad to know they are part of the kit.
Another common cause of slow leaks is a valve core that is either not tight enough or defective. I've had to replace a couple over the years.
01-01-2015, 09:40 PM
I wonder if the tire spec for pressure is just the max they are rated for by the tire manufacturer as opposed to the recommended working pressure.
I had a bad stem valve on one tire that created a slow leak until I replaced the valve stem - saved some money and hassle there!
Maybe it's just me, but I find it tough to judge the tire pressure state by sight with the wheel pants installed.
Rich
