Old 12-31-2014, 11:29 AM
Bevan Bevan is offline
Default Van's oil cooler 20006A occupancy dimensions?
I am helping a hangar neighbor with his "non-standard" oil cooler woes (non-RV). Due to an oil cooler leak and difficulty in finding a replacement, I would like to suggest we put on a real aircraft oil cooler such as what Van's sells for the RV10. Harrison/Stewart 20006A as used for an 0-540.
Does anyone have their cowl off and can tell me how much real estate the cooler occupies on the baffle and the rectangular hole size? Also,
For those that have remote mounted their cooler, can you tell me how much real estate the scat tube adapter occupies on the baffle?
Thanks and Happy New Year
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 12-31-2014, 11:32 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
RV 10 uses a firewall mounted oil cooler, fed with 4" SCAT from the rear baffle.
Sorry, no dimensions...........
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-31-2014, 11:42 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
These ought to get you in the ballpark...
http://www.niagaraairparts.com/20006...ifications.pdf
http://www.mcfarlane-aviation.com/co...=0&Article=254 (look at part number 8000215)
Neal Howard
Airplaneless once again...
