Go Back   VAF Forums > Model Specific > RV-14
Old 12-30-2014, 01:29 PM
ShortSnorter ShortSnorter is offline
Default Did I just ruin this?
Yet another did I ruin this:
About 3/4 of the way through dimpling the flanges of the 915 stiffeners for the rudder I noticed that the female die was making an ever so slight impression in the crease of the bend on the stiffener. The pictures of the internal surface of the flange exaggerate (due to light reflection) the "impression" made by the side of the female die. On the reverse side you can see and feel (albeit ever so slight) the protrusion. I do have reduced diameter dies but did not think to use them or check the clearance before I started whacking away on the C-Frame. What is the consensus?
Old 12-30-2014, 01:35 PM
BillL BillL is offline
I think structurally, no. The stress region of the stiffener is on the edge at the beginning of your arrows. Stiffeners are cheap, so you could replace them with the next order pretty easy, if it bothers you.
It happens.
Oh - remember that one of the high probability occurrences in back riveting the stiffeners is to rivet OFF the backing plate, just a reminder.
Bill
RV-7
Old 12-30-2014, 01:37 PM
Mel's Avatar
Mel Mel is offline
Build--on!
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-30-2014, 02:08 PM
Thanks Bill!
It happens.
Hahah I've been down that road already. Hopefully I got all of that out on the practice projects.
Originally Posted by Mel View Post
Build--on!
Thanks Mel!
Old 12-30-2014, 02:21 PM
plehrke's Avatar
plehrke plehrke is offline
If it was in the skin I would redo since small dents are highly amplified visually when painted. In stiffener I would just move on.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 12-30-2014, 03:01 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
I ground part of the die face outside of the dimple area away so this would be less likely to happen.
Dave
M20C
Old 12-30-2014, 03:11 PM
Ron B. Ron B. is offline
You should use a small diameter female die for this application. Many places you will need one during the build. Get a #40 and a # 30.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-30-2014, 04:00 PM
wirejock's Avatar
wirejock wirejock is offline
Default Dies
All my female dies have a flat side for that reason. When dimpling with the squeezer I always tape the flat side to the head of the yoke so it can't rotate.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 12-30-2014, 04:16 PM
If there's a protrusion on the skin side of the stiffener and it's not very high, it'll be within the coat of Pro-Seal that some of us paint on the stiffener before riveting. If you're not doing that - if you're planning on riveting it bare, then any protrusion could affect the contour or flatness of the skin.
(The Pro-Seal is to hopefully avoid any skin cracking, although I think that's more prevalent with the .016 skins on the older airplanes like my RV-3B. It might not be worth doing on yours. And even on the older aircraft, it's only done, usually, for surfaces in the slipstream. I think.)
The only other thing to check for is whether there's any zero-radius bending, which aluminum doesn't like. Those are crack-initiation points, although as BillL pointed out, this isn't the most highly-stressed area of the stiffener.
If it were mine, and if either of these were the case, I'd replace them. Heck, I've replaced so many parts that a stiffener more or less wouldn't be noticed.
Dave
RV-3B, now building the second pair of fuel tanks, sigh....
Old 12-30-2014, 05:25 PM
rvbuilder2002's Avatar
Correct
There are numerous instances that the manual will specify to use a reduced diam. female die. It is listed in the recommended tools list.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
