« The fourth need to go to the input on your audio system. The headset can't amplify the low signal. My guess. YMMV »
I think you could be right, but why Van’s site announces that one can connect the tone generator directly to the headset jacks?
http://www.vansaircraft.com/cgi-bin/...t=stall-warner
“Use a temporary test wire and connect the third wire connection to ground and see if it works.
If it does, check to make sure you have a wire connecting the common terminal of the stall sensor switch to ground. The tone activates when the activation wire becomes connected to ground.”
I have checked the continuity of the wire that connects the sensor switch to the tone generator and it was correct. And when I trigger the sensor vane, I hear a click out of the stall warning plate, but nothing in my headset. So I think the problem is not with the ground of that sensor switch, or with the sensor switch itself, or with the wire that connect it to the tone generator.
I have also bypassed the sensor switch of the vane with a jumper wire that I connected directly from ground to the «sensor» connection on the tone generator and heard a click out of the stall warning plate, but still nothing in my headset.
I have connected the other end of the wire that is connected to the «Audio mixer/Audio input» connection on the tone generator, to each spring blades of the earphone’s jack, one after the other, and still no sound in my headset. I did same with the spring blades of the micro’s jack without any result.
Unless Van is wrong when it says that I can connect the tone generator directly to the headset jacks, I think that, as taildrgr wrote, the problem is with the tone generator itself.
Before I order a new tone generator, could you tell me were I should connect the «Audio mixer/Audio input» wire of the tone generator to make a last test? I have no audio mixer. The only radio I have is a Garmin SL40.
Thanks for your help. Alain
