Old 12-27-2014, 11:12 AM
67MK Larry 67MK Larry is offline
Default Nose gear leg replace and bearing evaluation
I will be replacing nose gear leg shortly due to excess play in bolt hole and it is original gear leg. At condition inspection I notice a play between gear leg top and bearing in mount. Is there any advice on replacing this bearing or is it a "pull the engine" issue.???
Old 12-27-2014, 01:27 PM
Bevan Bevan is offline
Which bearing are you referring to? The bolt at the top of the nose gear leg secures the leg directly to the engine mount. If there is play, it is possible that just the bolt is damaged. Try replacing the bolt (properly torqued) and see if the "play" goes away. If not, consider reaming the whole assembly to the first oversize and buy NAS oversize bolts available from an excellent vendor here on VAF. See Gahco.
http://gen-aircraft-hardware.com/hardware.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 12-27-2014, 01:31 PM
Default Thanks for reply
When mechanic and I did "condition inspection" it looked like there was a brass or bronze bearing or bushing coming down at base of engine mount gear leg hole.
Old 12-27-2014, 01:41 PM
Are you able to post a picture? I'm assuming you've got an RV6A there?
Bevan
Dual P-mags
Grand Rapids EFIS
Old 12-27-2014, 01:54 PM
Default update
Will get pictures next week, Im sure it was a bushing or bearing in there nothing in the logs, I questioned builder and second owner, they both said nose gear never removed. Yes it is a 6A with 750 hours. I will talk to Vans next week and update. Thanks.
Old 12-27-2014, 01:55 PM
simpkinsona simpkinsona is offline
Default Nose gear
The builder off my A model used some shims at the bottom of the nose gear mount to prevent any side movement of the gear in the mount. The gear movement you need to check for and stop is movement up at the top of the mount where the bolt goes. I check that by putting my finger on the end of the gear leg and rocking the plane side to side. You can feel if the gear lg rotates or moves in the mount. You can also put your finger on the bolt as you rock the plane.
-Andy
Andy Simpkinson
RV-9a Subaru engine.
