Old 12-27-2014, 09:52 AM
riobison riobison is offline
Default Rebuilding your own Vacuum Pump?
It looks like my vacuum pump needs replacing on my RV4. I don't think I'm ready to go through all of the work involved to change over to a glass cockpit so I will change out the vacuum pump on my 0360 A1A.
I see that there are kits available that a person can buy and then rebuild the pump himself.
I can't imagine that these pumps are that complicated so are there any negatives to me doing this? Or should I bite the bullet and just buy one that is already rebuilt?
Tim
Old 12-27-2014, 01:03 PM
John RV8 John RV8 is offline
Default Vacuum pump
I have have done the rebuild process, but it was a lot of years ago. But as I recall it was pretty easy. The kit back then just had new parts for the core of the pump. Just be careful not the clamp the main body of the pump in a vise when you take it apart or reassemble
John Goodloe
RV-8. N6279G
Pay in November
Old 12-27-2014, 01:17 PM
You might consider a wet vacuum pump. I think they are more reliable.
Dave
Old 12-27-2014, 01:47 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Dave
++1 If you are going to have a vacuum pump, IMHO the only way to get reliability is a wet pump. I find the dry pumps today are junk.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-27-2014, 03:37 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The dry pumps work fine if you have the filter on them and rebuild every 500-600 hours or so. Very few will go 1000 hours. Cheap and easy to rebuild.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 12-27-2014, 04:21 PM
rvbuilder2002's Avatar
Be aware, that doing a quality rebuild requires one step that most people can't easily do.
The bore surface within the pump that the vans run against typically get wash boarded/rippled from the bouncing of the vanes (same as a wash boarded dirt road).
Depending on how bad the wash boarding is, you can have a very quick failure of the newly overhaul pump because of the higher level of rotational friction from the vanes catching while they wear in to the surface.
A true overhaul includes lightly machining the interior of the bore to remove any surface imperfections.
A pump doesn't usually fail because the vanes got too warn, it fails because the bore got too wash boarded and the high friction caused failure of the vanes and or shearing of the frangible coupling.
Scott McDaniels
Hubbard, Oregon
Old 12-27-2014, 06:15 PM
aerhed aerhed is offline
American Airpower has what you need. If you have ANY WASHBOARDING in the stator replace it. The trickiest part is replacing the carbon bushing. If yours is not cracked and the spline shaft isn't rattly just leave it. You may have to do a little sanding with 400 on the vanes and/or the top of the new rotor if its tight. When final assembled it HAS to turn freely with just a TINY drag. Don't spin the new one backwards until its run in. CHANGE THE FILTER AND MAKE SURE THE HOSES ARE SPOTLESS.
Actual repeat offender.
Old 12-27-2014, 06:26 PM
erikpmort's Avatar
erikpmort erikpmort is offline
I have a rapco one for sale cheap if Ya want pm me
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
Old 12-27-2014, 08:39 PM
RV6_flyer's Avatar
I have rebuilt one. As someone else mentioned, the Stator will more than likely need replaced. To install the carbon bushing, you need a special tool and there is no guarantee that you will be able to replace without breaking at least one.
If you add up the cost of the parts and tool, you will be very close to the cost of one rebuilt by Professionals and not need to spend several hours to rebuild your old one.
The difference in cost, just get a rebuilt one or as someone else said, get a wet vacuum pump.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 12-28-2014, 01:46 AM
The dry pump I have has 600hrs on it and won't produce enough vacuum on the ramp to bring the gyros up to speed. In the air they are ok, adjusting the regulator helped for a while but obviously its worn out and needs replacing.
It is sounding like if the stator needs changing then things can add up in a hurry. The rotor would be cheaper, quick and easy. Buying another stator over and above the rotor then the parts will add up in a hurry. Buying special wrenches or tools and if I break a rotor changing it out and having to buy a 2nd one would take me back close to the cost of a rebuilt one.
A wet pump for a VFR machine is about 3 times the cost of a dry pump and not worth the investment.
Tim
