Old 12-27-2014, 03:00 AM
Randy Randy is offline
Default Getting Silicone where you want it
Has anyone got any tips to share regarding getting high temp silicone in places that are difficult to access with the standard little tubes and nozzle that you cut?
I am looking for something available to extend the nozzle out so I can apply the stuff in areas that the normal short tube will simply not reach. I am hoping there might be some extended screw on nozzles available somewhere...
Randall in Sedona
Finishing up baffles and nearly ready to seal them to the engine.
Old 12-27-2014, 03:52 AM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
I have heard that some guys get those big syringes from a tractor supply store. That gets it in place, but you still need to finish the fillet with something. To me, it also wastes a lot of sealant left in the tube.
I just took one of those big popsicle sticks that I use for mixing fiberglass resin and broke it in half lengthwise so it was maybe 3/8 inch wide.
I made a nice rounded end on it and squirted the permatex on the end of the stick. Then I smeared the sealant down on the engine and baffe intersection in the hard to reach areas.
It came out reasonably well. I went slowly and did not overdo the sealant. If you don't put too much on and have a steady hand, it looks just fine.
Some areas you have to build up in layers.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 12-27-2014, 04:29 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I've used plastic tubing to extend the reach occasionally. I also use a lot of masking tape to keep the stuff off the parts where I don't want it.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 12-27-2014, 05:20 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Popsicle stick. Useful on baffles for getting around the cylinders and case.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 12-27-2014, 05:57 AM
Christer's Avatar
Christer Christer is offline
Default Loctite 598 aerosol
I used Loctite 598 in the aerosol cartridge and added a piece of scrap 1/4 tubing with a flared end. This gave me a long skinny tube to get in just about anywhere.
Christer
Director of Maintenance, SteinAir Inc.
RV-8 Completed
Old 12-27-2014, 06:33 AM
larrynew's Avatar
larrynew larrynew is online now
I used the same Semco sealant gun and 2.5 tube that I used for Proseal. I left the RTV in the tube with a plug in the tip and it's still fresh after a month.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 12-27-2014, 07:10 AM
DanH's Avatar
DanH DanH is offline
.....and the gray-black color looks so much better than orange high-temp, even if you put it on ugly!
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-27-2014, 07:33 AM
Gary 40274 Gary 40274 is offline
Default Straw
Just grab the straw from your latest soft drink, cram it on the tip of your RTV and you have a trimable flexible installation tool.
Gary
Old 12-27-2014, 07:53 AM
Thanks for the replies!
I did not know the Loctite 598 was available in an aerosol dispensor. This sounds like a great way as you can then concentrate on where it is going rather than squeezing the darn tube to get the stuff to go to flow. Now to try to find some... Home Depot?
Randall
Old 12-27-2014, 09:04 AM
pilotkms's Avatar
pilotkms pilotkms is offline
Default Amazon
Just ordered it for $16. Also ordered some 5699. It looks to be a lighter grey.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
