Old 12-18-2014, 12:50 PM
Dorfie Dorfie is offline
Default 3/16 to 1/4 quick coupling
The metal pitot and AOA tubes on the Garmin GSA26 are 3/16 OD and the tubing to the instruments are 1/4". How did you connect the two? So far I could not find a quick connect that changes size.
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 12-18-2014, 01:03 PM
garyz garyz is offline
Default connector
Stein has them thats were I got mine
Old 12-18-2014, 03:01 PM
airguy's Avatar
airguy airguy is offline
Lowes hardware store, aviation fittings department...
Old 12-18-2014, 03:40 PM
N15JB N15JB is offline
McMaster-Carr has them also.
Jim Berry
RV-10
Old 12-18-2014, 05:35 PM
Cannot find it on their website. I will call them. 1/4" to 1/4 only ones I can see.
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
Old 12-18-2014, 05:36 PM
I spent a lot of time in the store looking for them. Could not find the 3/16" to 1/4" transition. But I will look again.
Thanks. You give me hope!!
Johan
Dorfie
RV10 Flying, N245JM
Old 12-18-2014, 07:20 PM
I ordered mine from SteinAir when I ordered the pitot.
Old 12-18-2014, 08:26 PM
N427EF N427EF is offline
Default It's been a while
I remember trying to solve the same problem in the same place.
I think the 3/16 aluminum tube fits inside the 1/4" Nylon tube, pretty tight actually.
A piece of glue lined shrink hose will seal the deal air tight.
It is as good as any fitting and will last as long as a fitting.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
