MUFFLERS ON RV EXHAUST SYSTEMS my experience with Supertrapps
I read thru some past postings about exhaust/mufflers etc. Someone even mentioned about "Supertrapp" mufflers or cherry bomb glasspacks,,,,etc..etc.
This is my past experience with one style of muffler on my -6. I started out with a Vetterman crossover exhaust in 1999. Noisy?? not to bad. I wanted a little more peace and quiet in the cockpit so I kicked around the idea of hanging two Supertrapp Mufflers on the Vetterman exhaust, so I purchased at close to $200 each for a pair from Summit Racing, stainless steel to boot but not 321 stainless, heavy yes. I have used Supertrapps on my Alcohol Sprint cars with no problems other than a repack of the fiberglass once a season and they held up quite nice. Airplanes are a different story. Within 10 hours flying time on my -6 all of the glass packing was burned out along with the diffuser discs cracking and falling apart. They will not hold up to the constant high EGT's. Another problem is that they are not 321 stainless. Something else I noted with them was that when the glass packing started to melt, it turned into solid chunks of glass and nearly plugged up the round diffuser discs at the outlet. I found this out with EGT's getting erratic. DO not use them on an aircraft unless you baby the thing and putter around at low power. Were they quiet?? YES, very quiet the first few hours and I knocked off 6 DB of noise inside the cockpit for the first few hours until they failed. I would suggest, but anyone can do what they want, "Glass packed mufflers will probably not last on an airplane" with EGT's running at max all the time. They will be quiet at first then burn out the glass packing later. I only wanted to share my experience with the Supertrapp Mufflers I tried. Happy flying, Alan
Alan (AJ) Judy
Beaver, OK in NO MANS LAND
RV-6 IO360A1B6 C/S Hartz 200HP ?
Also Fly North American NAVIONs
Race car engine builder/Machinist/Fabricator 1982--present.
