12-14-2014, 07:54 PM
Gear driven standby alternator recomendation?
So, besides the SD-8, what other options are there? I have heard that a big problem for the SD-8 is it really doesn't supply many amps at 2400 rpm as it is rated at 8.4 amps at 3500 rpm. Obviously that number is of little help, since we usually run around 2400-2500 rpm. Any other options out there?
Thanks!
RV-7 Flying Since March 2015
N412HC
Titan IOX-370
SDS Tunable Injectors
EFII Dual Ignition and Fuel Injection
Garmin G3X Touch
Whirl Wind 200RV Prop
7XS0 Polly Ranch Airpark, Friendswood, TX
12-14-2014, 08:07 PM
Look at the B&C SD-20 if you feel the its baby brother won't do it for you.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-14-2014, 08:40 PM
Originally Posted by carrollcw
... 3500 rpm. Obviously that number is of little help, since we usually run around 2400-2500 rpm...
Actually, the vacuum pump drive runs at 1.3 times crankshaft speed... which means 2700 prop RPM = 3500 vacuum pump RPM.
12-14-2014, 08:41 PM
I guess they call the sd-20 the bc410-H now. Looks like plane power makes a couple too. Anyone have any experience with these? I like how the plane power alternator is internally regulated.
N412HC
Titan IOX-370
Garmin G3X Touch
12-14-2014, 08:43 PM
Thanks for correcting me. That makes more sense! I was wondering why they'd post those numbers!
N412HC
Titan IOX-370
Garmin G3X Touch
12-15-2014, 12:35 PM
Plane Power
I have the 30amp Plane Power. Was easy to install (540), don't have to load shed at all with it. With EFIS and LED lights I can have everything on and still see charging on my battery. Only flying a year, and just test it (by using it instead of primary) every couple months on a flight.
Does make getting the oil filter on & off a little harder as there is very little clearance between it and the oil filter.
Bill
12-15-2014, 01:55 PM
alt
I have 250 hrs. on 30 amp rear pad Plane Power as my only charging source. Is a little weak, but acceptable, below 900 engine rpm. Have had no issues with low battery. My total normal flight load is 7 amps. Also have backup battery for g3x panel. I am working on another plane and intend to do it the same way but have a B&C instead of the Plane Power but have had no issue's with the Plane Power. Ron
12-15-2014, 02:25 PM
SD8 rocks!
Thanks!
I have 250 hours on the SD8 in my RVX with no issues. My entire panel and dual EI only draw 5.4 amps. With an odessey battery it has been no issues.
V/R
Smokey
12-15-2014, 05:40 PM
SD-8
Sorry if this is off topic, but I was considering the SD-8 also. How difficult is installation of the unit for backup power?
John
12-15-2014, 06:56 PM
SD-20
I have a B&C SD-20 as a back up on my RV-4 and the best I've seen it give me is around 13.4 volts at 2400 RPM ( Engine )..
I think that I should get around 13.8 Volts with it
I adjusted the regulator a couple times already and looks like I'm gonna have to do it again..
Anyone has any numbers so I could compare..
Bruno
