Old 12-14-2014, 04:31 PM
9erDriver 9erDriver is offline
Default paint booth light REDO
OK, heeding the sage advice of my fellow VAF'ers and not wanting to foul my lights with paint nor blow myself to smithereens, I built a plastic covered soffit around my new lights. I will then open up the wall behind them allowing them to run in fresh air and effectively isolating them from the paint fumes. Not much of a reduction in light, still substantially more than before the upgrade. Thanks for the advice guys!
Steve Pofahl
A&P Mechanic Specializing in Experimental Aircraft
Owner - TechOps Aircraft Services
KBKX Brookings SD
RV9A x2, RV8A, Glasair S2RG, RV14 in progress
Old 12-14-2014, 04:46 PM
1001001's Avatar
1001001 1001001 is online now
Please also make sure that the switches are *outside* the plastic envelope of the paint booth. Non-explosion-proof switches are great sources of sparks for ignition of flammable vapors.
Old 12-17-2014, 07:11 AM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
You will need lights down low near the floor as well. The more light shinning at all angles is best. I just stood fluorescent light ups around the exterior of the booth all around.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 12-17-2014, 07:28 AM
Troy makes a good suggestion - the more "all over" light the better since you will regularly need to look from several angles to see thin spots, runs, etc.
my paint booth has white walls and a white floor to help "bounce" light but it would be better if I had lights low in the walls.
Old 12-17-2014, 07:40 AM
MikeyDale's Avatar
I have decided to use Stewart Systems waterborne paint. I'm going against the grain but my lights are going inside the booth. (Let the flaming begin!) The capture below is off of the Stewart Systems Video and the lights are inside. I'm pretty sure they paint everyday in this booth. I have read their paint is a little finicky but I'm going to give it a try as I have no prior painting experience. The advantages of spraying and cleaning up water based paint are too many to ignore for me.
[IMG][/IMG]
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 12-17-2014, 08:01 AM
Vansconvert's Avatar
Vansconvert Vansconvert is offline
I visited Stewart' location, and the picture of the booth set-up is what I saw - common flourescent strips inside the booth. Another advantage to water-based paint.
RV-7A
IO-360 Hartzell CSP
Purchased
Old 12-17-2014, 10:46 AM
NYTOM NYTOM is offline
Smile Thinking of using Stewart myself
Hey Mike, how about a review of your experience and the results of your Stewart paint job. I've painted planes and cars before at home and at this point I'm more afraid of my Wife's wrath than explosions. Urethane smell has a way of permeating into everything and will remind your wife for weeks every time you pull into the garage about what you did to her clean home. Funny but I kind of like that "smell"
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP
Old 12-17-2014, 12:02 PM
MikeyDale's Avatar
I will. I hope to start painting some in January or February if weather allows. My shop is heated but I dont think I can keep the temps up for long with the fans going in the booth if it is below 40 or 50 outside . I will probably watch the weather and wait for warm spells to spray. I will be shooting Insignia White EkoCrylic. I have all the cut and buff tools and supplies used in Dan H's cut and buff threads if needed.
Mike Hillger
Garden City, Texas
Dues Paid
Old 12-17-2014, 03:48 PM
Default Steward's drying time
Thanks Mike, I'll be watching for it. Drying time is one of my concerns. Their site said something about 4 or 5 hours to be dust free. I don't know if I can keep my grimy fingers away from it that long. Good luck with your paint job.
Tom Norwood
TMX-O360 FP
