Old 12-13-2014, 06:58 PM
jmvolpp jmvolpp is offline
Default RV-6 roll servo bracket
Our jointly owned RV6 is about to be upgraded with the Dynon AP74 autopilot and it's been noticed that the roll servo bracket, to be attached to the floor between 2 vertical structural components (the proper name of which I don't know), will overlap the longitudinal tab of the one on its left/outboard side while firmly against the one on the right. Presumably it's preferable to place a shim (.040"?) beneath it?
Mike V.
Old 12-13-2014, 07:10 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Yep, it will sit on the flange of the seat pan rib. I lofted mine slightly with a shim to avoid that problem. Additionally, I didn't want to drill through the skin to mount it so I attached it to the seat pan ribs.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 12-13-2014, 09:31 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I think you will find a 0.025 shim to be a more suitable thickness, not including any dimples.
If a rivet gets in the way, either drill a clearance hole in the bracket, or remove the rivet and re-use the hole with a longer rivet to hold the bracket.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
